StarTech.com Wall Mount Arm - Dual Swivel
Quicklinx: CRYJWS00 Mfr#: ARMWALLDS
Accessory Type: Mount
21 In Stock
£31.31 ex VAT
£37.57 inc VAT
Save space by wall-mounting your monitor, and maximize viewing with the swiveling extension arm. Wall-mount your computer monitor or flat-screen TV to free up space on your desk or table. This wall-mount monitor arm supports flat-panel displays up to 27" and provides a full 15" (382 mm) arm extension for optimum screen adjustment. The pivoting arm swivels +90° / - 90°, plus tilts and rotates to provide maximum viewing flexibility.
This monitor arm helps you save space on your desk or table surface, by letting you securely wall-mount a computer monitor or LED / LCD TV from 13" to 27" (330 to 686 mm) in size and up to 33 lb. (15kg) in weight. It's ideal for many different applications, including business, healthcare or financial settings, where you may want to share your screen with patients, clients, or other visitors. The wall-mount monitor arm also works well in office settings or workspaces that back against a wall.
The monitor arm extends a full 15" (381 mm) making it easy to change your screen position, so you can work more comfortably or share your screen with others. The dual-swivel arm offers a full +90° / - 90° swivel, to move your screen easily to the left or right and share your screen with maximum viewing flexibility. It tilts freely +70° / - 70°, allowing easy angle adjustment up or down to share your display, while collaborating with team members.
The aluminum wall-mount monitor arm features slide-in wall plate construction for easy installation. To help keep your work area free of clutter, the monitor arm also features a cable clip that keep your cables neatly out of sight.
StarTech.com Monitor Wall Mount - Dual Swivel - Supports 13'' to 34'' Monitors - VESA Monitor / TV Wall Mount - Wall Mount Swivel Monitor Arm - Black (ARMWALLDS) mounting kit - adjustable arm - for LCD display - black
Mounting kit (adjustable arm) - wall-mountable
Mounting Components
Mounting plate, screws, monitor arm
40 cm x 12 cm x 12 cm
Adjustable Depth
Up to 38.2 cm
Tilt
-70° to 70°
Swivel
180°
Adjustments
Pan, tilt, swivel
948 g
Recommended Use
LCD display
Recommended Display Size
13"-34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
15 kg
Material
Aluminium
Package Content
4 x M5x14 screws, hex key (4mm), hex key (5mm), hex key (2.5mm), 4 x M4x14 screws
5-year warranty
40 cm
12 cm
12 cm
Adjustable Depth
Up to 38.2 cm
948 g
Material
Aluminium
Package Content
AV Furniture
Mounting kit
Mounting Components
Design
Adjustable arm
Recommended Use
LCD display
Placing / Mounting
Wall-mountable
Cable Management
Integrated cable management
13"-34"
Tilt
-70° to 70°
Swivel
180°
Adjustments
Pan, tilt, swivel
Max Load Weight
15 kg
Limited warranty - 5 years
CRYJ StarTech.com Monitor Wall Mount - Aluminum In Stock £16.91
CRYJ StarTech.com Wall Mount Arm - Single Swivel In Stock £22.13
CRYJ StarTech.com Thin Client Mount - VESA In Stock £23.19
CRYJ StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £51.28
CRYJ StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
CRYJ StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
CRYJ StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.60
