StarTech.com Wall Cable Raceway with Adhesive Tape - 32x11mm - Outside Elbow
Quicklinx: FY22WS00 Mfr#: CBMWWD3211O
£8.12 ex VAT
£9.74 inc VAT
20 Pack Outside Elbow Connector White UL Approved. This 20-pack of raceway outside elbows works with the StarTech.com CBMWWD3211 raceway system.
Join Two Raceways Together Around Corners at a 90 Degree Angle
Use these cable raceway outside elbows with the StarTech.com CBMWWD3211 raceway to join two of them together and run them around corners at a 90 degree angle in your office or server room.
Industrial Strength
Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
Use in Combination with Other Raceway Accessories
Combine this coupler with other StarTech.com CBMWWD3211 raceway system accessories to give your cable management solution a finished look.
The Coupler (CBMWWD3211C) (20-Pack), joins two raceways together and extends the length of your raceway.
The End Piece (CBMWWD3211E) (20-Pack), cleanly caps off the end of your raceway.
The Inside Elbow (CBMWWD3211I), joins two raceways together inside of corners at 90 degree angle.
The Lateral Elbow (CBMWWD3211L), joins two raceways together and runs them up the wall at a 90 degree angle.
The T Connector (CBMWWD3211T), joins three raceways together in T-bar.
These cable management raceway outside elbows are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Join two raceways together around corners at a 90 degree angle
    Use these cable raceway outside elbows with the CBMWWD3211 raceway to join two of them together and run them around corners at a 90 degree angle in your office or server room.
  • Industrial strength
StarTech.com 20 Pack Cable Raceway Outside Corner Connectors for CBMWWD3211, Cable Management Accessories, Channel Raceway Fitting, Wiring Duct 90 Degree Outside Elbow, Plastic, UL Listed - ABS Plastic, UL94 HB (CBMWWD3211O) - cable raceway outside corner - TAA Compliant
Cable raceway outside corner
Packaged Quantity
20 (specifications are for single item)
3.256 cm x 3.244 cm x 3.384 cm
4 g
Product Material
Acrylonitrile butadiene styrene (ABS)
White
TAA Compliant
P/N: CBMWWD3211
Packaged Quantity
Product Material
3.256 cm
3.244 cm
3.384 cm
4 g
Enclosure Colour
White
Self-extinguishing, UL rated
TAA Compliant
Shipping Width
22.7 cm
Shipping Depth
18.4 cm
Shipping Height
4.5 cm
Shipping Weight
100 g
P/N: CBMWWD3211
