Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
StarTech.com Wall Cable Raceway with Adhesive Tape - 32x11mm - Lateral Elbow
Quicklinx: FY13WS00 Mfr#: CBMWWD3211L
£3.66 ex VAT
£4.39 inc VAT
20 Pack Lateral Elbow Connector White UL Approved. This 20-pack of raceway lateral elbows work with the StarTech.com CBMWWD3211 raceway system.
Join Two Raceways Together and Run them up the Wall at a 90 Degree Angle
Use these cable raceway lateral elbows with the StarTech.com CBMWWD3211 raceway to join two of them together at a 90 degree angle to extend the length of your raceway up walls in your office or server room.
Industrial Strength
Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct elbow connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
Use in Combination with Other Raceway Accessories
Combine this lateral elbow with other StarTech.com CBMWWD3211 raceway system accessories to give your cable management solution a finished look.
The Coupler (CBMWWD3211C) (20-Pack), joins two raceways together and extends the length of your raceway.
The End Piece (CBMWWD3211E) (20-Pack), cleanly caps off the end of your raceway.
The Inside Elbow (CBMWWD3211I) (20-Pack), joins two raceways together inside of corners at a 90 degree angle.
The Outside Elbow (CBMWWD3211O) (20-Pack), joins two raceways together around corners at a 90 degree angle.
The T Connector (CBMWWD3211T) (20-Pack), joins three raceways together in T-bar.
These cable management raceway lateral elbows are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Join two raceways together and run them up the wall at a 90 degree angle
    Use these cable raceway lateral elbows with the CBMWWD3211 raceway to join two of them together at a 90 degree angle to extend the length of your raceway up walls in your office or server room.
  • Industrial strength
StarTech.com 20 Pack Cable Raceway L Connector for CBMWWD3211, 90 Degree Right Angle, Flat L Type, Cable Management Accessories, Channel Raceway/Wiring Duct Fitting Lateral Elbow UL Listed - ABS Plastic, UL94 HB (CBMWWD3211L) - cable raceway L connector - TAA Compliant
Cable raceway L connector
Packaged Quantity
20 (specifications are for single item)
6.613 cm x 6.615 cm x 1.322 cm
7 g
Product Material
Acrylonitrile butadiene styrene (ABS)
White
TAA Compliant
P/N: CBMWWD3211
Packaged Quantity
Product Material
6.613 cm
6.615 cm
1.322 cm
7 g
Enclosure Colour
White
Self-extinguishing, UL rated
TAA Compliant
Shipping Width
30.3 cm
Shipping Depth
22.4 cm
Shipping Height
4 cm
Shipping Weight
142.86 g
P/N: CBMWWD3211
