StarTech.com Wall Cable Raceway with Adhesive Tape - 32x11mm - Coupler
Quicklinx: FY0YWS00 Mfr#: CBMWWD3211C
£7.74 ex VAT
£9.28 inc VAT
20 Pack Coupler Connector White UL Approved. This 20-pack of raceway couplers work with the StarTech.com CBMWWD3211 raceway system.
Join Two Raceways Together
Use these cable raceway couplers with the StarTech.com CBMWWD3211 raceway to join two of them together and extend the length of your raceway in your office or server room.
Industrial Strength
Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
Use in Combination with Other Raceway Accessories
Combine this coupler with other StarTech.com CBMWWD3211 raceway system accessories to give your cable management solution a finished look.
The End Piece (CBMWWD3211E) (20-Pack), cleanly caps off the end of your raceway.
The Inside Elbow (CBMWWD3211I) (20-Pack), joins two raceways together inside of corners at 90 degree angle.
The Lateral Elbow (CBMWWD3211L) (20-Pack), joins two raceways together and runs them up the wall at a 90 degree angle.
The Outside Elbow (CBMWWD3211O) (20-Pack), joins two raceways together around corners at a 90 degree angle.
The T Connector (CBMWWD3211T) (20-Pack), joins three raceways together in T-bar.
This cable management raceway coupler is TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Join two raceways together and run them up the wall at a 90 degree angle
    Use these cable raceway lateral elbows with the CBMWWD3211 raceway to join two of them together at a 90 degree angle to extend the length of your raceway up walls in your office or server room.
  • Industrial strength
    Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct elbow connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
StarTech.com 20 Pack Cable Raceway Coupler for CBMWWD3211, Cable Management Accessories, Channel Raceway Fitting Coupler, Midway Connectors, Wiring Duct Straight Connector, UL Listed - ABS Plastic, UL94 HB (CBMWWD3211C) - cable raceway coupler - TAA Compliant
Cable raceway coupler
Packaged Quantity
20 (specifications are for single item)
5.162 cm x 3.331 cm x 1.324 cm
3 g
Product Material
Acrylonitrile butadiene styrene (ABS)
White
TAA Compliant
P/N: CBMWWD3211
Packaged Quantity
Product Material
5.162 cm
3.331 cm
1.324 cm
3 g
Enclosure Colour
White
Self-extinguishing, UL rated
TAA Compliant
Shipping Width
23.1 cm
Shipping Depth
18.2 cm
Shipping Height
3.7 cm
Shipping Weight
80 g
P/N: CBMWWD3211
