78 in. (2 m) |Adhesive Tape Self Extinguishing PVC M1 Rated NF Fire Resistant. This 39 in. (1 m) cable management raceway with adhesive tape neatly routes cables in your office or server room, while also concealing them to create a tidy and professional look.
Professionally Organize & Route Cables
This cable management raceway protects cables from damage while neatly routing them in your office or server room. The raceway is 0.43 in. (11 mm) x 0.75 in. (19 mm).
Hassle-Free Installation
With an adhesive backing, the cable raceway can be installed by simply peeling off the protective backing and sticking it to your desired location on any surface, including wood, drywall, glass or masonry.
Industrial Strength
Made from self extinguishing PVC, that's sturdy and warp proof this network/power cable hider/concealer is M1 Rating NF fire resistant with a 186F (86C) Vicat softening point and are UL/94V-0 Rated.
Give Your Raceway a Finished Look with these Accessories
To combine and route this cable management raceway and cap off the ends, StarTech.com offers a wide selection of raceway accessories.
The Coupler (CBMWWD1911C) (20-Pack), joins two raceways together and extends the length of your raceway.
The End Piece (CBMWWD1911E) (20-Pack), cleanly caps off the end of your raceway.
The Inside Elbow (CBMWWD1911I) (20-Pack), joins two raceways together inside of corners at a 90 degree angle.
The Lateral Elbow (CBMWWD1911L) (20-Pack), joins two raceways together and runs them up the wall at a 90 degree angle.
The Outside Elbow (CBMWWD1911O) (20-Pack), joins two raceways together around corners at a 90 degree angle.
The T Connector (CBMWWD1911T) (20-Pack), joins three raceways together in a T-bar.
This cable management raceway is TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
Professionally organize & route cables
This cable management raceway protects cables from damage while neatly routing them in your office or server room. -
Hassle-free installation
With an adhesive backing, the cable raceway can be installed by simply peeling off the protective backing and sticking it to your desired location on any surface, including wood, drywall, glass or masonry. -
Industrial strength
- StarTech.com Solid Cable Management Raceway with Adhesive Tape & Cover, 3/4"(19mm)W x 3/8"(11mm)H, 3ft(1m) length, PVC Network/Power Cord Hider/Wall Wire Duct, Max 6 Cables, UL Listed - UL94 V0, M1 Fire Rated (CBMWWD1911) - cable raceway - TAA Compliant
- Product Type
- Cable raceway
- 1.9 cm 1.1 cm
- Length
- 2 m
- 106.25 g
- Product Material
- PVC
- White
- TAA Compliant
- 2-year warranty
- Product Type
- Cable raceway
- Product Material
- PVC
- 1.9 cm
- 1.1 cm
- Length
- 2 m
- 106.25 g
- Enclosure Colour
- White
- Self-extinguishing, adhesive tape, M1 Rated NF Fire Resistant
- TAA Compliant
- Limited warranty - 2 years
