StarTech.com Wall Cable Raceway with Adhesive Tape - 19x11mm - Inside Elbow
Quicklinx: FY0RWS00 Mfr#: CBMWWD1911I
£4.97 ex VAT
£5.96 inc VAT
20 Pack Inside Elbow Connector White UL Approved. This 20-pack of raceway inside elbows work with the StarTech.com CBMWWD1911 raceway system.
Join Two Raceways Together Inside Corners at a 90 Degree Angle
Use these cable raceway inside elbows with the StarTech.com CBMWWD1911 raceway to join two of them together at a 90 degree angle to extend the length of your raceway inside corners of your office or server room.
Industrial Strength
Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct elbow connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
Use in Combination with Other Raceway Accessories
Combine this inside elbow with other StarTech.com CBMWWD1911 raceway system accessories to give your cable management solution a finished look.
The Coupler (CBMWWD1911C) (20-Pack), joins two raceways together and extends the length of your raceway.
The End Piece (CBMWWD1911E) (20-Pack), cleanly caps off the end of your raceway.
The Lateral Elbow (CBMWWD1911L) (20-Pack), joins two raceways together and runs them up the wall at a 90 degree angle.
The Outside Elbow (CBMWWD1911O) (20-Pack), joins two raceways together around corners at a 90 degree angle.
The T Connector (CBMWWD1911T) (20-Pack), joins three raceways together in T-bar.
These cable management raceway inside elbows are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Join two raceways together and run them up the wall at a 90 degree angle
    Use these cable raceway lateral elbows with the CBMWWD1911 raceway to join two of them together at a 90 degree angle to extend the length of your raceway up walls in your office or server room.
  • Industrial strength
StarTech.com 20 Pack Cable Raceway Inside Corner Connectors for CBMWWD1911, Cable Management Accessories, Channel Raceway Fitting, Wiring Duct 90 Degree Inside Elbow, Plastic, UL Listed - ABS Plastic, UL94 HB (CBMWWD1911I) - cable raceway inside corner - TAA Compliant
Cable raceway inside corner
Packaged Quantity
20 (specifications are for single item)
3.397 cm x 3.371 cm x 2.145 cm
3 g
Product Material
Acrylonitrile butadiene styrene (ABS)
White
TAA Compliant
P/N: CBMWWD1911
Packaged Quantity
Product Material
3.397 cm
3.371 cm
2.145 cm
3 g
Enclosure Colour
White
Self-extinguishing, UL rated
TAA Compliant
Shipping Width
17.7 cm
Shipping Depth
14.9 cm
Shipping Height
4.7 cm
Shipping Weight
50 g
P/N: CBMWWD1911
