StarTech.com Wall Cable Raceway with Adhesive Tape - 19x11mm - "T" Connector
Quicklinx: FY0WWS00 Mfr#: CBMWWD1911T
£4.35 ex VAT
£5.22 inc VAT
20 Pack Outside T Connector White UL Approved. This 20-pack of raceway T-bars works with the StarTech.com CBMWWD1911 raceway system.
T-Branch Three Raceways Together at 90 Degree Angles
Use these cable raceway T-bars with the StarTech.com CBMWWD1911 raceway to join three of them together and make a right-angle T-branch in your office or server room.
Industrial Strength
Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
Use in Combination with Other Raceway Accessories
Combine this coupler with other StarTech.com CBMWWD1911 raceway system accessories to give your cable management solution a finished look.
The Coupler (CBMWWD1911C) (20-Pack), joins two raceways together and extends the length of your raceway.
The End Piece (CBMWWD1911E) (20-Pack), cleanly caps off the end of your raceway.
The Inside Elbow (CBMWWD1911I), joins two raceways together inside of corners at 90 degree angle.
The Lateral Elbow (CBMWWD1911L), joins two raceways together and runs them up the wall at a 90 degree angle.
The Outside Elbow (CBMWWD1911O) (20-Pack), joins two raceways together around corners at a 90 degree angle.
These cable management raceway outside elbows are TAA compliant and backed by a StarTech.com Lifetime warranty and free 24/5 technical support. StarTech.com has been the IT professionals choice for over 30 years.
  • Join two raceways together and run them up the wall at a 90 degree angle
    Use these cable raceway lateral elbows with the StarTech.com CBMWWD1911 raceway to join two of them together at a 90 degree angle to extend the length of your raceway up walls in your office or server room.
  • Industrial strength
    Made from sturdy self-extinguishing ABS that's also warp proof, these wiring duct elbow connectors are UL approved with 94HB Flamability (Horizontal Burning) Rating.
StarTech.com 20 Pack Cable Raceway T Connector for CBMWWD1911, Cable Management Accessories, 3 Way Raceway Fitting Connectors, T Type Connector, Wiring Duct Tee Connector, UL Listed - ABS Plastic, UL94 HB (CBMWWD1911T) - cable raceway T connector - TAA Compliant
Cable raceway T connector
Packaged Quantity
20 (specifications are for single item)
7.237 cm x 4.614 cm x 1.259 cm
4.5 g
Product Material
Acrylonitrile butadiene styrene (ABS)
White
TAA Compliant
P/N: CBMWWD1911
Packaged Quantity
Product Material
7.237 cm
4.614 cm
1.259 cm
4.5 g
Enclosure Colour
White
Self-extinguishing, UL rated
TAA Compliant
Shipping Width
24 cm
Shipping Depth
22 cm
Shipping Height
3.7 cm
Shipping Weight
100 g
P/N: CBMWWD1911
