Turn a USB port into a virtual 7.1 channel Sound Card. This USB to Audio Adapter lets you connect headphones or speakers, and a microphone to your computer without the need to unplug other devices!
Compliant with USB 2.0 and USB audio device specification 1.0, this USB to audio adapter couldn't be any simpler to install.
Compatible with Windows 98SE and up, the USB Audio Adapter integrates into any computer environment, providing superb sound quality and convenience that can't be matched.
Included with the USB Audio Adapter is the Xear 3D software for virtual 7.1 channel sound for use with Windows XP and Windows Vista.
- StarTech.com Virtual 7.1 USB Stereo Audio Adapter External Sound Card - Sound card - stereo - USB 2.0 - ICUSBAUDIO7 - sound card
- Sound card
- Enclosure Type
- External
- Interface Type
- USB 2.0
- 2.54 cm x 5.7 cm x 1.4 cm
- 14 g
- Black
- Sound Output Mode
- Stereo
- Hardware Controls And Indicators
- Volume control, mute button
- System Requirements
- Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 10 (32/64 bits)
- 2-year warranty
- Designed For
- P/N: MU15MMS, MU6MMS
- Sound card
- Form Factor
- External
- Interface Type
- USB 2.0
- 2.54 cm
- 5.7 cm
- 1.4 cm
- 14 g
- Enclosure Colour
- Black
Audio Output
- Sound Output Mode
- Stereo
- USB bus-powered
- 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone stereo 3.5 mm
- FCC, RoHS
- Software
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
- Designed For
StarTech.com 6 ft 3.5mm Stereo Audio Cable - M/M | In Stock | £4.64 |
StarTech.com USB Stereo Audio Adapter External Sound Card with SPDIF Digital Audio | In Stock | £23.31 |
StarTech.com 7.1 Channel PCIe Sound Card | In Stock | £41.21 |
