StarTech.com Video Wall Mount - Steel
Quicklinx: D3VDWS00 Mfr#: VIDWALLMNT
Type: Bracket
£291.81 ex VAT
£350.17 inc VAT
Create a professional video wall, with fast and easy rear-screen access and display adjustment. This professional video-wall mount features an innovative pop-out design that enables fast and easy display alignment and adjustment, within a multi-display video wall.
Engineered with heavy-duty steel, the video-wall mount securely supports 45" to 70" displays, weighing up to 154 lb. (70 kg).
Using multiple VIDWALLMNT wall mounts, you can create an impressive video wall, enabling you to align your displays in unison. It's the ideal solution for public, business and commercial displays and includes an anti-theft feature (with padlock required).
With its unique pop-out design, the video wall mount helps you align your displays with perfect precision. Once installed, you simply press gently on the front of the display and the mount extends out from the wall for rear-screen access. This pop-out feature makes it easy to adjust the position and angle of the display, or replace a display when required.
The video-wall mount features 6 points of micro-adjustment, with vertical, tilt and swivel adjustments, to provide exact display alignment and an optimum viewing angle. You can tilt your display +3° / -5°, adjust the swivel angle +1.2° / - 1.2°, and rotate the display +3° / - 3°. The video-wall mount also features lateral shift brackets, making it easy to move the display to the left or right for ideal alignment in your video wall.
This video-wall mounting system is designed for easy set-up and maintenance. The pop-out design also assists in installation and maintenance, plus a convenient kickstand allows you to tilt the display up to 12° giving you extra room when adjusting cables or accessing ports.
  • A Versatile Video Wall Mounting System
    Engineered with heavy-duty steel, the video-wall mount securely supports45" to 70" displays, weighing up to 154 lb. (70 kg). Using multiple VIDWALLMNT wall mounts, you can create an impressive video wall, enabling you to align yourdisplays in unison. It's the ideal solution for public, business and commercial displays and includes a theft deterrence feature (padlock required).
  • Align Your Displays Seamlessly
    With its unique pop-out design, the video wall mount helps you align yourdisplays with perfect precision. Once installed, you simply press gently on thefront of thedisplay and the mount extends out from the wall for rear-screen access. This pop-out feature makes it easy to adjust the position and angle of the display, or replace a display when required. The video-wall mount features 6 points of micro-adjustment, with vertical, tilt and swivel adjustments, to provide exact display alignment and an optimum viewing angle. You can tilt your display +3 / -5 degrees, adjust the swivel angle +1.2/ - 1.2 degrees, and rotate the display +3 / - 3 degrees. The video-wall mount also features lateral shift brackets, making it easy to move the display to the left or right for ideal alignment in your video wall.
StarTech.com Video Wall Mount - For 45" to 70" Displays - Pop-Out - Micro-Adjustment - Steel - VESA Wall Mount - TV Video Wall System (VIDWALLMNT) bracket - for video wall - black
Bracket - wall-mountable
30.6 cm x 93.4 cm x 48.3 cm
Tilt
-5°
Levelling
-3° to 3°
Adjustments
Levelling
15.7 kg
Recommended Use
Video wall
Recommended Display Size
45"-70"
Max Mounting Pattern Size
600 x 400 mm
Max Load Weight
70 kg
Material
Aluminium, steel
Package Content
4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x20 screws, 4 x M8x30 screws, 8 x spacers (small), 6 x concrete anchors, 6 x 6.3x55 mm screws, hex key, 2 x adapter brackets, 4 x rectangular washers, wall plate, adjustment module, 2 x stoppers, 2 x plastic tabs, 4 x spacers (large), 6 x washers
5-year warranty
P/N: HDMIPLATE, ST121SHD50, ST12MHDLAN, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLANRX
30.6 cm
93.4 cm
48.3 cm
15.7 kg
Material
Aluminium, steel
Package Content
AV Furniture
Bracket
Recommended Use
Video wall
Placing / Mounting
Wall-mountable
600 x 400 mm
45"-70"
Tilt
-5°
Levelling
-3° to 3°
Adjustments
Levelling
Max Load Weight
70 kg
Limited warranty - 5 years
D3VD StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) In Stock £92.94
D3VD StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £16.00
D3VD StarTech.com HDMI Over IP Extender Kit - 4K In Stock £464.90
D3VD StarTech.com ST12MHDLAN4K Receiver In Stock £259.38
D3VD StarTech.com 10m CL2 Active HDMI Cable - 4K In Stock £81.45
D3VD StarTech.com Full Motion TV Wall Mount In Stock £253.81
D3VD StarTech.com VESA TV Wall Mount Full Motion In Stock £87.44
Type: Bracket
