The STUTPEALRGB is the receiver unit utilized by the STUTPEAGB VGA and audio over Cat 5 extension series. This convenient video distribution system simplifies implementing digital signage solutions by allowing a single VGA source and corresponding audio to be broadcast to multiple displays at up to 300m (950ft) away.
Comprised of one receiver unit per display, as well as a 4 port VGA & audio extender unit (ST124UTPEAGB) or an 8 port VGA & audio extender unit (ST128UTPEAGB), the VGA and audio extension series can transmit a single VGA output and corresponding audio to 4 or 8 displays/receivers over standard Cat 5 UTP cable.
For even more versatility, the VGA & audio over Cat 5 Line Splitter (STUTPEA4XGB) can be used to multiply the number of potential displays by four - allowing the VGA signal and accompanying audio to be broadcast to up to 16 or 32 VGA displays.
- StarTech.com VGA Video Extender over Cat 5 Remote Receiver with Audio - video/audio extender
- Video/audio extender (receiver)
- Form Factor
- External
- Localisation
- United Kingdom
- Transmission Medium
- CAT 5
- Max Transfer Distance
- 300 m
- 11 cm x 13 cm x 2.5 cm
- 270 g
- 2-year warranty
- Form Factor
- External
- Black
- Localisation
- United Kingdom
- Connectivity Technology
- Wired
- Max Resolution
- 1280 x 1024 @ 60 Hz
- 300 m
- Status Indicators
- Power
- 1 x VGA (output) - HD-15 female , 1 x network - RJ-45 female , 1 x audio (output) - mini jack female
- FCC, RoHS
- Power Device
- External power adapter
- 11 cm
- 13 cm
- 2.5 cm
- 270 g
- Limited warranty - 2 years
- 0 °C
- 50 °C
- 5 - 90%
