Extend a VGA signal to a remote display using Cat5 cabling.
The ST121UTPEP VGA Video Extender over Cat5 - Point to Point lets you connect a remote VGA display/projector up to 80m (250ft) away from the VGA signal source. The ST121UTPEP is a bundled kit that includes both a local and a remote unit providing a complete end to end solution for a single source/display connection, transmitting the source VGA signal over a standard Ethernet cable (Cat5e or better UTP cable, terminated with RJ45 connectors).
Offering convenient and cost-effective VGA distribution, the ST121UTPEP only requires one power adapter which can be installed at either the local or remote end of the connection, depending on what is most convenient for your application.
To ensure a tidy installation, the ST121UTPEP includes a mounting bracket for the receiver to help eliminate unnecessary cable tangles.
Efficient video transmission
This VGA Over CAT5 Extender allows users to transmit VGA video signals across long distances, making it ideal for various applications in different settings. -
High-quality video output
With support for resolutions up to 1920 x 1200, this device ensures that the video displayed maintains clarity and detail at extended distances. -
Easy installation
Using standard CAT 5 cabling, installation becomes straightforward, allowing for quick setup without the need for specialized cables. -
Reliable compliance
This extender meets FCC and RoHS standards, ensuring it is safe for use and environmentally friendly. -
Includes essential components
The kit provides everything needed for operation, including one local unit and one remote unit, simplifying the overall installation process.
- StarTech.com VGA Over CAT5 Extender 250 ft (80m) 1 Local and 1 Remote Unit - VGA Video Over Ethernet Extender Kit (ST121UTPEP) - video extender
- Video extender
- Form Factor
- External
- Transmission Medium
- CAT 5
- Max Transfer Distance
- 80 m
- 10 cm x 13.8 cm x 2.5 cm
- 36 g
- 2-year warranty
- Designed For
- P/N: SVA12M2NEUA, SVA12M5NA
- Video extender
- Form Factor
- External
- Black
- Connectivity Technology
- Wired
- Max Resolution
- 1920 x 1200
- 80 m
- 1 x VGA - HD-15
- Cables Included
- 1 x VGA cable
- FCC, RoHS
- Power Device
- External power adapter
- 10 cm
- 13.8 cm
- 2.5 cm
- 36 g
- Limited warranty - 2 years
- Designed For
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £42.05 |
