The ST121RGB VGA over Cat5 video extender receiver is specifically designed for use as the receiver unit to the StarTech.com ST1214TGB 4 port VGA over Cat5 UTP Extender transmitter, allowing you to split and extend a single VGA source to up to four remote displays.
From the transmitter device, the VGA video signal is sent over standard 4 pair category 5 or better UTP cable to remote monitors, each connected to an ST121RGB Cat 5 VGA receiver - supporting distances of up to 150 meters (500 feet).
A cost-effective video extension solution, this receiver is ideal for a wide range of environments including airports, bus depots, retail, or any large buildings where VGA video needs to be extended to long connection distances.
- StarTech.com VGA over Cat 5 UTP Video Extender Receiver - video extender
- Video extender (receiver)
- Form Factor
- External
- Localisation
- United Kingdom
- Transmission Medium
- CAT 5
- Max Transfer Distance
- 150 m
- 2-year warranty
- Form Factor
- External
- Black
- Localisation
- United Kingdom
- Connectivity Technology
- Wired
- Max Resolution
- 1024 x 768
- 150 m
- 2 x VGA (output) - HD-15 female , 1 x display / video - input - RJ-45 female
- Power Device
- External power adapter
- Limited warranty - 2 years
