StarTech.com VGA/mDP Crash Cart Adapter
Quicklinx: J9X5WS00 Mfr#: NOTECONS02-VGA-MDP
£393.06 ex VAT
£471.67 inc VAT
This laptop USB 2.0 to KVM Console (NOTECONS02-VGA-MDP) turns your notebook into a portable server crash cart, eliminating the need to lug around a video screen, keyboard and mouse. This adapter delivers the VGA stream from any host computer to a laptop and emulates the laptop mouse/keyboard outputs for simple access/control of connected servers, PCs or other "headless" devices. Use the included Mini DisplayPort adapter to connect to mDP-enabled computers or servers. The software interface of the USB KVM crash cart makes it easy to transfer files from your datacenter laptop to the server, capture videos or take screenshots. You can scale the display window to full screen mode or smaller without having to scroll, which helps you troubleshoot faster. Ensuring full control of the connected units, the datacenter crash cart provides immediate access to the POST screen and BIOS, plus the ability to handle full configuration of the attached PC or machine; administrators can connect to a headless server without the need of an expensive LCD rackmount console or bulky monitor, keyboard and mouse solution. Please note that the mouse function may be limited in some BIOS/UEFI environments The drivers are device-specific, it's essential to match the driver installation to your NOTECONS02-VGA-MDP to ensure compatibility and functionality.
StarTech.com Portable Laptop Crash Cart Adapter, USB/VGA/Mini DisplayPort KVM Console, File Transfer and Video Capture - KVM switch - 1 ports - TAA Compliant
Subtype
KVM
Ports
1 x KVM port(s)
KVM Users Qty
1 local user
Plastic housing
197 g
Apple macOS Big Sur, Apple macOS Catalina, Apple macOS Mojave, Apple macOS Monterey, Apple MacOS Sierra, Apple macOS Sonoma, Apple macOS X El Capitan, Apple macOS High Sierra, Apple macOS Ventura, Linux 2.6 or later, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Linux LTS versions only
TAA Compliant
Enclosure Type
Desktop
Subtype
KVM
Ports
1 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200 @ 60 Hz
Plastic housing
Status Indicators
Console, host, keyboard, mouse, USB, VGA
1 x USB 2.0 Type A , 1 x USB mini-USB , 1 x VGA HD-15 , 1 x mini-DisplayPort
1 x USB host cable - 38.5 cm , 1 x USB-A to mini-USB Type B cable - 1.8 m , 1 x VGA cable - 29 cm , 1 x Mini DisplayPort-VGA adapter
FCC, RoHS, DisplayPort 1.2
TAA Compliant
197 g
Shipping Width
16.5 cm
Shipping Depth
30.1 cm
Shipping Height
5.5 cm
Shipping Weight
358 g
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
