The steel and aluminum construction of this VESA TV Wall Mount supports TVs from 23" to 55" and up to 66lb (30kg). The arm assembly provides smooth one-touch height adjustment thanks to its spring-loaded mechanism that acts as a counterbalance. The VESA plate supports mounting patterns of 75x75 to 400x400.
Versatile TV Mounting
Securely mount a flat or curved-screen TV or digital signage in a convenient location for viewing by visitors, clients, and employees. This TV wall mount is ideal for lobbies, boardrooms, and manufacturing facilities. The lateral range of 3.54 ft (1.08m) is ideal for corner mounting. The jointed arm folds on itself and creates a slim profile from the wall of just 2.2in (5.8cm) for limited space installations. The minimum TV weight is 17.6lb (8kg). M5/M6/M8 Screws of various lengths and an assortment of washers and spacers enhance TV mounting compatibility. Mount into wood-stud or concrete walls, using the included hardware. Supported VESA mounting patterns: 75x75,100x100, 200x100, 200x200, 300x300, 400x200, and 400x400. -
Full-Motion Adjustment
The VESA plate swivels +90 / -90 degrees, tilts +8 / -15 degrees, and rotates +3 / -3 degrees. Customize the viewing experience and comfort with these full-motion capabilities. The one-touch spring-assisted mechanism facilitates effortless height adjustments, with a range of up to 12.6in (32cm). The arm assembly extends up to 23.4 in (59.5 cm) from the wall to accommodate different viewing positions. -
Durable Construction
The robust steel and aluminum design safely and securely supports the TV. The arm assembly features built-in cable management and a wall mount cover for a an organized and visually appealing installation. The height adjustable TV wall mount is backed for two years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com VESA TV Wall Mount, TV Mounting Bracket For 23"-55" Displays, Adjustable Full Motion TV Wall Mount Supports 66lb (30kg), Extendable/Tilting/Swivel Monitor Wall Mount - Low Profile/Slim Display Mount (FHA-TV-WALL-MOUNT) mounting kit - for flat panel - TV Mounting Bracket - black, silver
- Product Type
- Mounting kit - wall-mountable
- 45 cm x 59.5 cm x 45 cm
- Tilt
- -15° to 8°
- Rotation
- -3° to 3°
- Swivel
- -90° to 90°
- Adjustments
- Tilt, swivel, rotation
- 6 kg
- Recommended Use
- Flat panel
- Recommended Display Size
- 23"-55"
- VESA Mounting Interface
- 75 x 75 mm, 100 x 100 mm, 200 x 100 mm, 200 x 200 mm, 300 x 300 mm, 400 x 200 mm, 400 x 400 mm
- Max Load Weight
- 30 kg
- Material
- Aluminium, steel
- Black, silver
- Package Content
- 2 decorative covers, 8 x VESA extension plate screws, wrench, hex key (4mm), hex key (6mm), spirit level, 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 4 x M8x50 screws, 4 display washers (large), 4 display washers (small), 2 x VESA extension plates (left), 2 x VESA extension plates (right), 8 x spacers (long), 8 x spacers (short), 5 wall mounting screws, 5 wall mounting washers
- 2-year warranty
- 45 cm
- 59.5 cm
- 45 cm
- 6 kg
- Material
- Aluminium, steel
- Black, silver
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- Flat panel
- Placing / Mounting
- Wall-mountable
- 23"-55"
- Tilt
- -15° to 8°
- Rotation
- -3° to 3°
- Swivel
- -90° to 90°
- Adjustments
- Max Load Weight
- 30 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 58.5 cm x 44 cm x 9.5 cm / 6.1 kg
- Limited warranty - 2 years
StarTech.com 10m CL2 Active HDMI Cable - 4K | In Stock | £81.45 |
StarTech.com VESA TV Wall Mount Full Motion
