StarTech.com VESA Mounting Bracket
Quicklinx: J1K0WS00 Mfr#: DOCK-NUC-VESA-MOUNT
More than 50 In Stock
£7.62 ex VAT
£9.14 inc VAT
  • Sturdy construction
    Constructed from robust steel, this mounting bracket provides a solid mount for monitors and docking stations, ensuring durability over time.
  • Versatile compatibility
    Designed to accommodate both 100 x 100 mm and 75 x 75 mm VESA mounting interfaces, providing flexibility for various monitor sizes.
  • Complete installation kit
    Included with the bracket are a variety of screws and spacers, allowing for hassle-free assembly and secure mounting of devices.
StarTech.com VESA Mounting Bracket for NUC/Thin Clients/Docking Stations mounting component - for thin client - black
Mounting component - monitor
Mounting Components
2 VESA mount brackets
30.5 cm x 12 cm x 0.15 cm
100 g
Recommended Use
Thin client
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Material
Steel
Package Content
4 x M3x15 screws, 4 x M3x5 screws, 4 x M4x5 screws, 4 x M4x12 screws, 4 x M4x20 screws, 4 x M5x12 screws, 4 x M5x20 screws, 4 washers, 8 x spacers
5-year warranty
30.5 cm
12 cm
0.15 cm
100 g
Material
Steel
Package Content
AV Furniture
Mounting component
Mounting Components
Recommended Use
Thin client
Placing / Mounting
Monitor
Dimensions & Weight Details
31 cm x 12.5 cm x 2 cm / 600 g
Limited warranty - 5 years
J1K0 StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter In Stock £63.03
J1K0 StarTech.com 4-Port USB C Hub USB 3.1 Gen 2 (10Gbps) 3x USB-A & 1x USB-C In Stock £59.00
