Sturdy construction
Constructed from robust steel, this mounting bracket provides a solid mount for monitors and docking stations, ensuring durability over time. -
Versatile compatibility
Designed to accommodate both 100 x 100 mm and 75 x 75 mm VESA mounting interfaces, providing flexibility for various monitor sizes. -
Complete installation kit
Included with the bracket are a variety of screws and spacers, allowing for hassle-free assembly and secure mounting of devices.
- StarTech.com VESA Mounting Bracket for NUC/Thin Clients/Docking Stations mounting component - for thin client - black
- Product Type
- Mounting component - monitor
- Mounting Components
- 2 VESA mount brackets
- 30.5 cm x 12 cm x 0.15 cm
- 100 g
- Recommended Use
- Thin client
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Material
- Steel
- Black
- Package Content
- 4 x M3x15 screws, 4 x M3x5 screws, 4 x M4x5 screws, 4 x M4x12 screws, 4 x M4x20 screws, 4 x M5x12 screws, 4 x M5x20 screws, 4 washers, 8 x spacers
- 5-year warranty
- 30.5 cm
- 12 cm
- 0.15 cm
- 100 g
- Material
- Steel
- Black
- Package Content
AV Furniture
- Recommended Use
- Thin client
- Placing / Mounting
- Monitor
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 31 cm x 12.5 cm x 2 cm / 600 g
- Limited warranty - 5 years
