ENHANCED PRODUCTIVITY: Use this VESA mount adapter to attach a tablet to a monitor for office/retail use - The tablet holder is compatible with iPad Pro 11in and other tablets with display size 7.9 to 12.5in - Up to 4.4lb and VESA patterns 75x75/100x100.
SECURE TABLET CRADLE: Anti-theft measures include tamper-resistant screws and optionally lock the tablet clamp to help protect the equipment - The lockable mount is ideal for retail, restaurant, self-checkout, and service applications.
INTUITIVE DESIGN: The secure table mount holds the tablet at opposite corners to avoid blocking any buttons, ports, or the front-facing camera. The black finish matches most monitor mounts or stands.
CONVENIENT MOUNTING: A weighted plate 0.7lb (0.35kg) is included to accommodate the typical minimum weight capacity of spring or gas-assisted monitor arm/mounts - The tablet clamp features a spring mechanism for easily mounting tablets of different sizes.
THE IT PRO'S CHOICE: Designed and built for IT Professionals, this universal anti theft tablet holder is backed for five years, including free lifetime 24/5 multi-lingual technical assistance.
VESA Mounting for Ergonomics
Attach a tablet to this adapter and secure it to a VESA-compatible (75 x 75 / 100 x 100 mm) single monitor mount for use in POS, hospitality, room/storage control, and retail applications. Add a display to an existing setup by attaching this adapter to an available VESA monitor mount or arm. Depending on the functional capabilities of the VESA mounting point, adjustments may be possible to the tablet's height and rotation/tilt angle. -
Lock and Secure a Tablet
The VESA tablet mount features anti-theft measures that can deter the theft of the attached tablet. These theft prevention features include anti-tamper mounting screws and lockable tablet clamps. Locking the clamp is optional. Keys and tools are included. -
Quick and Easy Installation
The clever design does not block the ports, front-facing camera, or buttons, allowing users to use all the tablet's features (remove any protective cases from the tablet). The 0.7 lb (0.35 kg) weighted plate can be added to the tablet mount, to ensure optimal operation of spring-assisted/one-touch monitor arms. The tablet VESA mount is backed for 5 years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com VESA Mount Adapter for Tablets 7.9 to 12.5in - Up to 2kg (4.4lb) - 75x75/100x100 VESA Patterns - Universal Anti-Theft Tablet VESA Mount Clamp - Secure Tablet Mount - Black mounting kit - for tablet - black
- Product Type
- Mounting kit - arm mountable, stand mountable, VESA bracket mounting - lockable
- Mounting Components
- Tablet security holder, weighted plate
- 23.7 cm x 16.1 cm x 4.1 cm
- Adjustments
- Height, rotation, tilt
- 600 g
- Recommended Use
- Tablet
- Recommended Display Size
- 7.9" - 12.5"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 2 kg
- Material
- Steel, plastic
- Black
- Package Content
- 2 keys, star bit tool, 4 x M4x10 screws, 4 x M4x8 screws, 4 x washers
- 5-year warranty
- Designed For
- Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation)
- 23.7 cm
- 16.1 cm
- 4.1 cm
- 600 g
- Material
- Steel, plastic
- Black
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- Tablet
- Placing / Mounting
- Arm mountable, stand mountable, VESA bracket mounting
- Lockable
- 7.9" - 12.5"
- Adjustments
- Max Load Weight
- 2 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 25.5 cm x 17.5 cm x 4.5 cm / 800 g
- Limited warranty - 5 years
- Designed For
StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black | In Stock | £8.30 |
StarTech.com 2 m / 6.6 ft USB 2.0 to USB C Cable – Black | In Stock | £10.00 |
StarTech.com 1 m / 3.3 ft USB C Cable – Black | In Stock | £8.90 |
