StarTech.com VESA Monitor Mount Adapter - Premium - VESA 75x75 and100x100
Quicklinx: FW6VWS00 Mfr#: APLVESAMNTP
£23.51 ex VAT
£28.21 inc VAT
Save space with this premium VESA monitor mount adapter, by connecting your display to one of the premium monitor mounts. It has convenient snap-and-click design for easy installation. The computer monitor mount adapter makes it easy to change your screen position, so you can work more comfortably. This product's attractive finish is ideal for customer-facing environments such as waiting rooms, lobbies.
  • Versatile Use
    Use the monitor stand adapter to mount your VESA mount monitor (75x75, 100x100) up to 34". You can also mount your Apple Cinema Display, 24-inch iMac, or Thunderbolt Display that came with a removable stand or built-in mount VESA adapter. The attractive silver finish complements Apple products.
  • Adjust Your Screen Position with Ease
    The computer monitor mount adapter makes it easy to change your screen position, so you can work more comfortably. It can rotate your display 360° and tilts freely +90°/ -15°.
  • Easy Installation
    The VESA pole mount adapter features thumb screws for easy installation on VESA displays. Tools are also included for attaching Apple iMacs, Cinema Displays, or Thunderbolt displays to the mount. The snap-and-click design is fully compatible with the following ergonomic display mounts: ARMDUAL30 , ARMDUALPS , ARMPIVOT , ARMQUADPS , ARMWALLDS2 , ARMWALLDSLP , WALLSTSI1 , WALLSTSI2 .
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. The APLVESAMNTP is backed by a StarTech.com 10-year warranty and free lifetime technical support.
StarTech.com Monitor Mount Adapter for Apple iMac, iMac Pro, Cinema & Thunderbolt Displays, Only for StarTech.com Premium Mounts, Apple Computer Articulating Monitor Bracket Kit, Silver - VESA Mount Adapter (APLVESAMNTP) mounting kit - for LCD display/ curved LCD display - silver - TAA Compliant
Mounting kit
Mounting Components
Flange, VESA mount
12 cm x 12 cm x 8.5 cm
Tilt
-15° to 90°
Swivel
-180° to 180°
Adjustments
Tilt, swivel
575 g
Recommended Use
Recommended Display Size
12"-34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
14 kg
Material
Steel
Silver
TAA Compliant
Package Content
Hex key (4mm), hex key (3mm), 4 x thumbscrews, 4 x plastic caps, Torx tool, 2 x M6x16 screws
10 years warranty
12 cm
12 cm
8.5 cm
575 g
Material
Steel
Silver
Package Content
AV Furniture
Mounting kit
Mounting Components
Flange, VESA mount
Recommended Use
12"-34"
Tilt
-15° to 90°
Swivel
-180° to 180°
Adjustments
Tilt, swivel
Max Load Weight
14 kg
TAA Compliant
Dimensions & Weight Details
12.5 cm x 12.5 cm x 9 cm / 650 g
Limited warranty - 10 years
FW6V StarTech.com Dual Monitor Mount - Stackable In Stock £212.73
FW6V StarTech.com Wall Mounted Computer Workstation - Extendable Monitor Arm In Stock £352.03
FW6V StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors In Stock £191.88
FW6V StarTech.com Wall Mount Monitor Arm-10.2" Swivel Arm up to 30" Monitors In Stock £62.55
FW6V StarTech.com Wall Mount Monitor Arm-20.4" Swivel Arm up to 30" Monitors In Stock £83.35
FW6V StarTech.com Quad Monitor Mount - Premium - For up to 27" VESA Monitors In Stock £395.70
