StarTech.com VESA-Certified DP 2.1 Cable
Quicklinx: HQ2XWS00 Mfr#: DP21-2M-DP40-CABLE
Length: 2m
18 In Stock
£14.14 ex VAT
£16.96 inc VAT
Discover a high-quality solution for your high-resolution display needs with the StarTech.com 2m DisplayPort 2.1 Cable. This VESA-Certified, DP40 DP 2.1 Cable is engineered to deliver a premium audiovisual experience, supporting up to 40 Gbps data transfer rates, HDR10, and Variable Refresh Rate (VRR). Whether you're gaming, streaming, or engaging in high-definition video playback, this cable is designed to meet your needs with support for 8K60Hz, 4K144Hz, and 1440p at 240Hz resolutions.
Constructed for durability, it features a 10,000 insertions lifespan, 600 bend lifespan, and strain relief, ensuring it withstands the rigors of regular use. The inclusion of EMI protection and halogen-free materials not only ensures the safety of your setup but also contributes to a more sustainable environment. With support for FreeSync and G-Sync, enjoy seamless, tear-free visuals that transform your viewing experience. Choose the StarTech.com DisplayPort cable for a reliable, high-quality connection that brings your content to life.
  • Enhanced durability
    Designed for longevity, this 2m DisplayPort 2.1 Cable boasts a 10,000 insertions lifespan and a 600 bend lifespan, ensuring reliable performance through extensive use. The ABS housing and strain relief further enhance its durability, making it a robust choice for your connectivity needs.
  • Superior audiovisual experience
    Experience high-quality audio and visual quality with support for 32 audio channels, HDR10, and Variable Refresh Rate (VRR). Whether it's gaming or streaming, the inclusion of FreeSync and G-Sync support provides a smooth, tear-free experience, elevating your viewing experience.
  • High-speed connectivity
    Achieve high data transfer rates of up to 40 Gbps with this VESA-Certified DP40 DP 2.1 Cable. It supports resolutions up to 8K60Hz, 4K144Hz, and 1440p at 240Hz, making it ideal for high-resolution gaming, detailed graphics work, and ultra-high-definition video streaming.
StarTech.com 2m DisplayPort 2.1 Cable, VESA-Certified, DP40 DP 2.1 Cable - DisplayPort cable - DisplayPort to DisplayPort - 2 m
DisplayPort cable
Shielded
Passive cable, 8K60Hz support, 4K144Hz support, 1440p support 240Hz, up to 40 Gbps data transfer rate, UHBR10, HDR support, strain relief, EMI protection, halogen free, copper conductors, DisplayPort Multi-Stream Transport (MST), 32 audio channels, HDR10 support, ABS housing, G-Sync support, FreeSync support, Variable Refresh Rate (VRR), 600 bend lifespan, 10000 insertions lifespan
Length
2 m
Connector
20 pin DisplayPort - male - latched
Connector (Second End)
DisplayPort 2.1
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30
Plated Connector
Nickel
Length
2 m
Outside Diameter
6.5 mm
106 g
Connector
DisplayPort 2.1, RoHS, WEEE, VW-1, HDCP 2.2, DSC 1.2a, VESA DP40
Shipping Width
22.5 cm
Shipping Depth
20 cm
Shipping Height
1.5 cm
Shipping Weight
120 g
HQ2X StarTech.com USB C to DP Adapter - 8K/4K In Stock £13.33
HQ2X StarTech.com VESA-Certified DP 2.1 Cable In Stock £14.14
HQ2X StarTech.com VESA-Certified DP 2.1 Cable In Stock £12.68
HQ2X StarTech.com VESA-Certified DP 2.1 Cable In Stock £20.05
Length: 2m
