Discover a high-quality connection with the StarTech.com 1m DisplayPort 2.1 Cable, VESA-Certified, DP80 DP 2.1 Cable. Engineered to meet the demands of high-performance gaming, professional streaming, and multimedia applications, this cable delivers exceptional visual and audio quality. With support for up to 16K60Hz, 8K85Hz, and 4K240Hz resolutions, you'll enjoy clear image clarity and fluidity. The inclusion of 32 audio channels along with HDR10 support ensures a rich, immersive audiovisual experience.
Durability is a cornerstone of this cable's design, featuring a 10,000 insertions lifespan, 600 bend lifespan, and strain relief to withstand the rigors of daily use. It's also equipped with FreeSync and G-Sync support, Variable Refresh Rate (VRR), and HDR compatibility, catering to the needs of gamers and professionals alike. Moreover, its eco-friendly construction, utilizing halogen-free materials and ABS housing, reflects a commitment to environmental sustainability without sacrificing performance.
High-quality visuals
Experience visual quality with support for 16K60Hz, 8K85Hz, and 4K240Hz, ensuring crisp, fluid, and lifelike images for gaming, streaming, and professional applications. -
Advanced audio and video features
With 32 audio channels, HDR10, and DisplayPort Multi-Stream Transport (MST), this cable offers a rich audiovisual experience, supporting immersive sound and vibrant visuals. -
Durable and reliable
Designed for longevity with a 10,000 insertions lifespan, 600 bend lifespan, and strain relief, this cable is built to last, ensuring a secure and stable connection for all your devices. -
Enhanced compatibility
Featuring FreeSync and G-Sync support, Variable Refresh Rate (VRR), and compatibility with HDR, this cable delivers smooth, tear-free gaming experiences across a wide range of devices. -
Eco-friendly design
Crafted with halogen-free materials and ABS housing, this cable is designed with environmental responsibility in mind, reducing harmful emissions without compromising on performance or durability.
- StarTech.com 1m DisplayPort 2.1 Cable, VESA-Certified, DP80 DP 2.1 Cable - DisplayPort cable - DisplayPort to DisplayPort - 1 m
- DisplayPort cable
- Technology
- Shielded
- UHBR20, HDR support, 16K60hz support, 8K85Hz support, 4K240Hz support, 1440p support 240Hz, up to 80 Gbps data transfer rate, passive cable, DisplayPort Multi-Stream Transport (MST), G-Sync support, FreeSync support, Variable Refresh Rate (VRR), 600 bend lifespan, strain relief, 10000 insertions lifespanins, HDR10 support, 32 audio channels, EMI protection, halogen free, copper conductors, ABS housing
- Length
- 1 m
- Connector
- 20 pin DisplayPort - male - latched
- Connector (Second End)
- DisplayPort 2.1
- Black
- 2-year warranty
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 30
- Plated Connector
- Nickel
- Length
- 1 m
- Outside Diameter
- 5.8 mm
- Black
- 80 g
- Connector
- DisplayPort 2.1, 8K VESA certified, DSC 1.2a, HDCP 2.2, RoHS, VW-1, WEEE
- Shipping Width
- 12.5 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 86 g
- 2-year warranty
StarTech.com USB C to DP Adapter - 8K/4K | In Stock | £13.33 |
StarTech.com VESA-Certified DP 2.1 Cable | In Stock | £16.45 |
StarTech.com VESA-Certified DP 2.1 Cable | In Stock | £14.75 |
