StarTech.com VESA-Certified DP 2.1 Cable
Quicklinx: HST7WS00 Mfr#: DP21-1M-DP40-CABLE
Length: 1m
£14.40 ex VAT
£17.28 inc VAT
The StarTech.com 1m DisplayPort 2.1 Cable is a VESA-Certified, high-performance cable designed to meet the needs of demanding multimedia professionals and gaming enthusiasts. With support for resolutions up to 8K60Hz and 4K144Hz, this cable delivers crystal-clear, high-definition visuals and supports HDR for vibrant colors and deeper contrasts. Gamers will benefit from FreeSync and G-Sync compatibility, ensuring a smooth, tear-free gaming experience. The cable is engineered for durability, featuring a robust design with a 600 bend lifespan, 10,000 insertions lifespan, and strain relief. It also offers up to 40 Gbps data transfer rate, making it ideal for high-bandwidth video and audio transmission. Additionally, the cable is equipped with EMI protection and latched connectors, ensuring a stable, secure connection and minimizing potential signal interference. Whether you're setting up a professional-grade video editing suite or a high-end gaming rig, the StarTech.com DisplayPort 2.1 Cable provides the reliability and performance you need.
  • High-quality visuals
    Experience stunning high-definition visuals with support for 4K144Hz and 8K60Hz, enhanced by HDR support for lifelike color and contrast. This cable ensures your display meets high standards for video quality.
  • Enhanced gaming experience
    Gamers will appreciate the inclusion of FreeSync and G-Sync support, along with a Variable Refresh Rate (VRR), to eliminate screen tearing and stuttering for a smoother, more immersive gaming experience.
  • Durable design
    Constructed with a 600 bend lifespan, 10,000 insertions lifespan, and strain relief, this cable is built to last. The ABS housing and halogen-free materials further ensure durability and safety.
  • Superior audio and video transmission
    With up to 40 Gbps data transfer rate and support for 32 audio channels, this cable delivers exceptional audio and video quality without compromise. HDR10 support and DisplayPort Multi-Stream Transport (MST) enable a comprehensive multimedia experience.
  • Reliable connectivity
    Featuring latched connectors and EMI protection, this cable ensures a secure, stable connection and minimizes potential interference, keeping your signal clear and uninterrupted.
StarTech.com 1m DisplayPort 2.1 Cable, VESA-Certified, DP40 DP 2.1 Cable - DisplayPort cable - DisplayPort to DisplayPort - 1 m
DisplayPort cable
Shielded
UHBR10, HDR support, 8K60Hz support, 4K144Hz support, 1440p support 240Hz, up to 40 Gbps data transfer rate, passive cable, DisplayPort Multi-Stream Transport (MST), Variable Refresh Rate (VRR), strain relief, 600 bend lifespan, 10000 insertions lifespan, HDR10 support, 32 audio channels, EMI protection, halogen free, G-Sync support, FreeSync support, ABS housing, copper conductors
Length
1 m
Connector
20 pin DisplayPort - male - latched
Connector (Second End)
DisplayPort 2.1
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30
Plated Connector
Nickel
Length
1 m
Outside Diameter
6.5 mm
66 g
Connector
DisplayPort 2.1, VESA DP40, HDCP 2.2, DSC 1.2a, WEEE, RoHS, VW-1
Shipping Width
12.8 cm
Shipping Depth
22 cm
Shipping Height
2.1 cm
Shipping Weight
70 g
HST7 StarTech.com USB C to DP Adapter - 8K/4K In Stock £13.33
HST7 StarTech.com VESA-Certified DP 2.1 Cable In Stock £24.23
Length: 1m
