StarTech.com VESA-Certified DisplayPort 2.1 Cable 3m
Quicklinx: J4KFWS00 Mfr#: DP21-3M-DP40-CABLE
Length: 3m
£27.48 ex VAT
£32.97 inc VAT
Connect an 8K/4K UHD DisplayPort monitor to a host computer or MST hub, using this VESA-Certified DisplayPort 2.1 DP40 Cable. This cable facilitates high bandwidth video and multi-channel audio and is ideal for 8K workstations, high performance GPUs, and dedicated AV applications including media production and content creation. The DP 2.1 Cable is VESA Certified for guaranteed DP 2.1 and backward compatibility (DP 2.0/1.4/1.2). It supports G-Sync and FreeSync, enhancing Variable Refresh Rate (VRR) performance for optimal picture quality between high-capacity GPUs and supported displays. This DisplayPort cable features a flexible TPE outer jacket that is tested to withstand 600 bending cycles at -/+60 degrees, and routes easily around corners and desk edges. Robust strain reliefs enable convenient positioning of the cable, and latching nickel-plated DP connectors attach securely to prevent accidental disconnection. The connectors are rated to operate beyond 10,000 insertions. This DP 2.1 Cable is constructed with braided aluminum mylar shielding to minimize EMI for clear, consistent audio/video output and long-term reliable performance.
  • Seamless Compatibility
    For seamless operation between DisplayPort-enabled devices, the DisplayPort 2.1 Cable is VESA Certified for guaranteed DP 2.1 and backward compatibility (DP 2.0/1.4/1.2). It supports G-Sync and FreeSync, enhancing Variable Refresh Rate (VRR) performance for optimal picture quality between high-capacity GPUs and supported displays.
  • Durable Design
  • Supported DisplayPort 2.1 Features:
    This DP40 DisplayPort cable supports the following DP 2.1 features: • Resolutions up to 8K 60Hz w/DSC, using a compatible DP source and display • UHBR10 supports high refresh rates including 4K 120Hz and 1440p 240Hz • High-Bandwidth Digital Content Protection (HDCP) 2.2 for a secure connection between source and display • High Dynamic Range 10 (HDR10) for higher contrast ratio and vibrant picture quality • Display Stream Compression (DSC) 1.2a for maximum resolution output • Multi-Stream Transport (MST) for daisy-chaining multiple monitors • 32 Uncompressed Digital Audio Channels • Backward compatible with previous DP versions This DP 2.1 Cable is constructed with braided aluminum mylar shielding to minimize EMI for clear, consistent audio/video output and long-term reliable performance.
StarTech.com 3m DisplayPort 2.1 Cable, VESA-Certified DP40 DP 2.1 Cable - DisplayPort cable - DisplayPort to DisplayPort - 3 m
DisplayPort cable
Shielded
8K60Hz support, 4K144Hz support, 1440p support 240Hz, UHBR10, HDR support, up to 40 Gbps data transfer rate, passive cable, HDR10 support, 32 audio channels, EMI protection, strain relief, halogen free, DisplayPort Multi-Stream Transport (MST), G-Sync support, FreeSync support, Variable Refresh Rate (VRR), 600 bend lifespan, 10000 insertions lifespan, copper conductors, ABS housing
Length
3 m
Connector
20 pin DisplayPort - male - latched
Connector (Second End)
DisplayPort 2.1
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30
Plated Connector
Nickel
Length
3 m
Outside Diameter
8.2 mm
315 g
Connector
DisplayPort 2.1, VESA DP40, HDCP 2.2, DSC 1.2a, RoHS, VW-1, WEEE
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
3 cm
Shipping Weight
325 g
Length: 3m
