StarTech.com Vertical Dual Monitor Stand
Quicklinx: F2K3WS00 Mfr#: ARMDUOVS
Accessory Type: Stand
£103.40 ex VAT
£124.08 inc VAT
This vertical dual-monitor stand, with its sleek aluminum design, raises two displays off the surface of your desk or table, to save space while increasing your productivity. With its robust construction, the freestanding dual-monitor mount securely holds two VESA mount monitors, each up to 27", stacked vertically.
The dual-monitor mount holds two displays, one above the other. You can adjust the height of the monitors along the 28" (710 mm) pole, to work in comfort with your two-monitor setup.
The adjustable monitor stand for desks enables smooth, effortless +15/-15 degree tilt and swivel, making it easy to find the perfect viewing angle. It can also rotate a full 360 degrees, giving you the flexibility of portrait or landscape viewing.
The dual-monitor stand securely holds your monitors in place while complimenting your office decor with its black and silver aluminum design. The monitor stand supports two monitors, each up to 27" (686 mm) in size and 17.6 lb. (8 kg) in weight.
The VESA monitor stand is easy to install, featuring quick monitor attachment and removal. It also provides cable management to keep your cables neatly out of sight.
  • Versatile monitor support
    Accommodates two monitors with sizes ranging from 13 inches to 27 inches, providing flexibility for various setups.
  • Adjustable viewing angles
    Offers tilt adjustments from -15° to 15°, along with a 360° rotation, enabling users to find their preferred angle easily.
  • Integrated cable management
    The built-in cable management system keeps wires organized and out of sight, ensuring a streamlined and professional workspace.
  • Sturdy construction
    Made from a combination of plastic and aluminum, this stand provides robust support while maintaining a lightweight profile.
  • Easy assembly
    Includes all necessary components, such as VESA monitor mounts and screws, making setup quick and hassle-free.
StarTech.com Vertical Dual Monitor Stand, Ergonomic Desktop Stacked Two Monitor Stand up to 27 inch VESA Mount Displays, Free Standing Universal Monitor Mount, Height Adjustable, Silver - Double Monitor Holder (ARMDUOVS) stand - for 2 monitors - black, silver
Stand - desktop stand
11.5 cm x 16 cm x 94 cm
Tilt
-15° to 15°
Rotation
360°
Swivel
-15° to 15°
Adjustments
Height, tilt, swivel, rotation
4.2 kg
Recommended Use
2 monitors
Recommended Display Size
13"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Plastic, aluminium
Black, silver
Package Content
2 x VESA monitor mounts, 8 x M4x30 screws, hex key (4mm), hex key (3mm), 8 x washers, 16 x spacers, lower pole, base, 8 x M4x14 screws, 8 x M5x14 screws, upper pole, pole connector, 2 x cable management hooks, 3 mm hex key with screwdriver tip, 2 x cable management hook screws, 8 x M5x30 screws
11.5 cm
16 cm
94 cm
4.2 kg
Material
Plastic, aluminium
Black, silver
Package Content
AV Furniture
Stand
Recommended Use
2 monitors
Placing / Mounting
Desktop stand
Cable Management
13"-27"
Tilt
-15° to 15°
Rotation
360°
Swivel
-15° to 15°
Adjustments
Max Load Weight
8 kg
Assembly Required
Dimensions & Weight Details
4.8 kg
F2K3 StarTech.com Dual Monitor Stand In Stock £80.12
F2K3 StarTech.com Vertical Dual Monitor Stand In Stock £79.68
F2K3 StarTech.com Thin Client Mount - VESA In Stock £22.48
F2K3 StarTech.com Dual Monitor Stand - Articulating - For Monitors up to 32" In Stock £131.53
F2K3 StarTech.com Dual-Monitor Stand - Horizontal - For up to 24" Monitors - S In Stock £82.81
F2K3 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £50.12
F2K3 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
F2K3 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
F2K3 StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.34
