StarTech.com Vertical Dual Monitor Stand
Quicklinx: CRXZWS00 Mfr#: ARMBARDUOV
Accessory Type: Stand
12 In Stock
£78.44 ex VAT
£94.12 inc VAT
Increase productivity and free up space by mounting two monitors, stacked, with this attractive desktop stand. This sturdy and sleek dual-monitor stand raises two displays off the surface of your desk or table, to save space while increasing your productivity. With its steel construction, the freestanding monitor stand securely holds two monitors, each up to 27", stacked vertically.
The dual-monitor stand holds two displays, one above the other, in a vertical configuration. You can work more comfortably, reducing neck and eye strain without having to look side to side when comparing files or reviewing reference material on your screens. It's ideal for numerous applications including web design, coding, creating and reviewing files, and many others. The monitor mount saves valuable desk space and lets you work clutter-free, which is a welcome addition in numerous office environments including business, healthcare and financial settings. You can adjust the height of the monitors as needed, along the 32.2" (818 mm) pole.
The monitor stand enables smooth, effortless +45°/-45° tilt and +45°/-45° swivel, making it easy to reduce glare and find the perfect viewing angle. It can also rotate a full 360° giving you the flexibility of portrait or landscape viewing.
The heavy-duty steel monitor stand holds your monitors securely in place, to protect your investment and provide long-lasting stability. The dual-monitor stand supports two displays 13" to 27" (330 to 686 mm) in size and 22.1 lb. (10 kg) in weight per monitor. The surface finish features a powder coating to help resist scratches.
For easier mounting, the VESA mount features notches that let you pre-set the mounting screw, then slide the monitor into place and tighten the screw. To help keep your work area free of clutter, the monitor stand also features cable clips that keep your cables neatly out of sight.
  • Sturdy construction
    Made from heavy-duty steel, this stand is engineered to support a maximum load weight of 10 kg, ensuring stability for both monitors.
  • Flexible adjustments
    This stand offers height, tilt, swivel, and rotation adjustments, allowing users to customize the setup for comfortable viewing positions.
  • Efficient cable management
    An integrated cable management system helps keep power and data cables organized, reducing clutter and improving usability.
  • Versatile mounting options
    Compatible with VESA mount interfaces of 100 x 100 mm and 75 x 75 mm, adapting easily to various monitor types.
  • Desktop design
    This stand is specifically designed for desktop placement, maximizing valuable desk space while providing an ergonomic solution.
StarTech.com Vertical Dual Monitor Stand - Supports Monitors 13" to 27" - Adjustable - Computer Monitor Stand for Double Stacked VESA Monitors - Black (ARMBARDUOV) stand - for 2 monitors - black
Stand - desktop stand
43.4 cm x 31.6 cm x 81.8 cm
Tilt
-45° to 45°
Pan
-45° to 45°
Rotation
360°
Adjustments
Height, tilt, swivel, rotation
4 kg
Recommended Use
2 monitors
Recommended Display Size
13"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10 kg
Material
Heavy duty steel
Package Content
Mounting hardware
5-year warranty
P/N: ACCSMNT, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV
43.4 cm
31.6 cm
81.8 cm
4 kg
Material
Heavy duty steel
Package Content
Mounting hardware
AV Furniture
Stand
Recommended Use
2 monitors
Placing / Mounting
Desktop stand
Cable Management
Integrated cable management
13"-27"
Tilt
-45° to 45°
Pan
-45° to 45°
Rotation
360°
Adjustments
Max Load Weight
10 kg
Assembly Required
Limited warranty - 5 years
CRXZ StarTech.com Universal USB 3.0 Laptop Docking Station Dual-Monitor HDMI DVI In Stock £65.29
CRXZ StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio In Stock £62.58
CRXZ StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video In Stock £48.91
CRXZ StarTech.com Dual Monitor Stand In Stock £80.12
CRXZ StarTech.com Vertical Dual Monitor Stand In Stock £78.44
CRXZ StarTech.com Vertical Dual Monitor Mount In Stock £67.16
CRXZ StarTech.com Dual 4K Docking Station, Mac & Windows - USB-A & USB-C Dock, Dual 4K60 DP & HDMI In Stock £93.68
CRXZ StarTech.com Thin Client Mount - VESA In Stock £22.48
CRXZ StarTech.com Under Desk Keyboard Tray In Stock £52.06
CRXZ StarTech.com USB-C Multiport Adapter Docking Station In Stock £118.27
CRXZ StarTech.com Vertical Dual Monitor Stand In Stock £103.40
CRXZ StarTech.com Dual Monitor Stand - Articulating - For Monitors up to 32" In Stock £131.53
CRXZ StarTech.com Dual-Monitor Stand - Horizontal - For up to 24" Monitors - S In Stock £82.81
CRXZ StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.34
