Increase productivity and free up space by mounting two monitors, stacked, with this attractive desktop stand. This sturdy and sleek dual-monitor stand raises two displays off the surface of your desk or table, to save space while increasing your productivity. With its steel construction, the freestanding monitor stand securely holds two monitors, each up to 27", stacked vertically.
The dual-monitor stand holds two displays, one above the other, in a vertical configuration. You can work more comfortably, reducing neck and eye strain without having to look side to side when comparing files or reviewing reference material on your screens. It's ideal for numerous applications including web design, coding, creating and reviewing files, and many others. The monitor mount saves valuable desk space and lets you work clutter-free, which is a welcome addition in numerous office environments including business, healthcare and financial settings. You can adjust the height of the monitors as needed, along the 32.2" (818 mm) pole.
The monitor stand enables smooth, effortless +45°/-45° tilt and +45°/-45° swivel, making it easy to reduce glare and find the perfect viewing angle. It can also rotate a full 360° giving you the flexibility of portrait or landscape viewing.
The heavy-duty steel monitor stand holds your monitors securely in place, to protect your investment and provide long-lasting stability. The dual-monitor stand supports two displays 13" to 27" (330 to 686 mm) in size and 22.1 lb. (10 kg) in weight per monitor. The surface finish features a powder coating to help resist scratches.
For easier mounting, the VESA mount features notches that let you pre-set the mounting screw, then slide the monitor into place and tighten the screw. To help keep your work area free of clutter, the monitor stand also features cable clips that keep your cables neatly out of sight.
Sturdy construction
Made from heavy-duty steel, this stand is engineered to support a maximum load weight of 10 kg, ensuring stability for both monitors. -
Flexible adjustments
This stand offers height, tilt, swivel, and rotation adjustments, allowing users to customize the setup for comfortable viewing positions. -
Efficient cable management
An integrated cable management system helps keep power and data cables organized, reducing clutter and improving usability. -
Versatile mounting options
Compatible with VESA mount interfaces of 100 x 100 mm and 75 x 75 mm, adapting easily to various monitor types. -
Desktop design
This stand is specifically designed for desktop placement, maximizing valuable desk space while providing an ergonomic solution.
- Startech Vertical Dual Monitor Stand - Supports Monitors 13" to 27" - Adjustable - Computer Monitor Stand for Double Stacked VESA Monitors - Black (ARMBARDUOV) stand - for 2 monitors - black
- Product Type
- Stand - desktop stand
- 43.4 cm x 31.6 cm x 81.8 cm
- Tilt
- -45° to 45°
- Pan
- -45° to 45°
- Rotation
- 360°
- Adjustments
- Height, tilt, swivel, rotation
- 4 kg
- Recommended Use
- 2 monitors
- Recommended Display Size
- 13"-27"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 10 kg
- Material
- Heavy duty steel
- Black
- Package Content
- Mounting hardware
- 5-year warranty
- Designed For
- P/N: ACCSMNT, DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV
- 43.4 cm
- 31.6 cm
- 81.8 cm
- 4 kg
- Material
- Heavy duty steel
- Black
- Package Content
- Mounting hardware
AV Furniture
- Stand
- Recommended Use
- 2 monitors
- Placing / Mounting
- Desktop stand
- Cable Management
- Integrated cable management
- 13"-27"
- Tilt
- -45° to 45°
- Pan
- -45° to 45°
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 10 kg
- Assembly Required
- Limited warranty - 5 years
- Designed For
StarTech.com Universal USB 3.0 Laptop Docking Station Dual-Monitor HDMI DVI | In Stock | £67.64 |
StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio | In Stock | £56.02 |
StarTech.com StarStarTech.com Universal USB 3.0 Laptop Docking Station w/ Dual DVI Video | In Stock | £33.91 |
StarTech.com Dual Monitor Stand | In Stock | £82.12 |
StarTech.com Vertical Dual Monitor Stand | In Stock | £80.40 |
StarTech.com Vertical Dual Monitor Mount | In Stock | £68.85 |
StarTech.com Thin Client Mount - VESA | In Stock | £23.04 |
StarTech.com Under Desk Keyboard Tray | In Stock | £53.36 |
StarTech.com Vertical Dual Monitor Stand | In Stock | £105.98 |
StarTech.com Dual Monitor Stand - Articulating - For Monitors up to 32" | In Stock | £134.82 |
StarTech.com Dual-Monitor Stand - Horizontal - For up to 24" Monitors - S | In Stock | £84.89 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.52 |
