StarTech.com Vertical Dual Monitor Mount
Quicklinx: CRY2WS00 Mfr#: ARMDUALV
14 in stock
£60.85 ex VAT
£73.02 inc VAT
Save workspace and increase productivity by mounting two monitors, stacked, above your desk. This sturdy and sleek dual-monitor mount raises two displays off the surface of your desk or table, to save space while increasing your productivity. With its steel construction, the dual-monitor mount attaches easily to your desk or table to securely hold two monitors, each up to 27", stacked vertically.
The dual-monitor mount holds two displays, one above the other, in a vertical configuration. The height of the monitors can be adjusted, as required, along the 27.5" (700 mm) pole.
With the dual-monitor mount, you can work more comfortably, reducing neck and eye strain without having to look side to side when comparing files or reviewing reference material on your screens. It's ideal for numerous applications including web design, coding, creating and reviewing files, and many others. The monitor mount saves valuable desk space and lets you work clutter-free, which is a welcome addition in numerous office environments including business, healthcare, and financial settings.
The monitor mount enables smooth, effortless +45°/-45° tilt and +45°/-45° swivel, making it easy to reduce glare and find the perfect viewing angle. It can also rotate a full 360° giving you flexible viewing options.
The heavy-duty steel monitor mount holds your two monitors securely in place to protect your investment, and provide long-lasting performance. The dual-monitor mount supports two displays 13" to 27" (330 to 686 mm) in size and 22.1 lb. (10 kg) in weight per monitor. The surface finish features a powder coating to help resist scratches.
The dual-monitor mount makes it easy to mount your VESA mount compatible displays above your desk, table or other surfaces, using the included C-clamp or grommet mount. For easier mounting, the VESA mount features notches that let you pre-set the mounting screw, then slide the monitor into place and tighten the screw. To help keep your work area free of clutter, the monitor mount also features cable clips that keep your cables neatly out of sight.
StarTech.com Vertical Desk Mount Dual Monitor Arm - For Monitors 13" to 27" - Adjustable - Desk Clamp / Grommet-Hole Mount - Dual VESA Monitors - Black (ARMDUALV) - desk mount
Desk mount - desktop
11.6 cm x 12 cm x 90 cm
Tilt
-45° to 45°
Pan
-45° to 45°
Rotation
360°
Adjustments
Tilt, swivel, rotation
Recommended Use
2 monitors
Recommended Display Size
13"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10 kg
Material
Heavy duty steel
Package Content
Mounting hardware
5-year warranty
P/N: DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV
11.6 cm
12 cm
90 cm
Material
Heavy duty steel
Package Content
Mounting hardware
AV Furniture
Desk mount
Recommended Use
2 monitors
Placing / Mounting
Desktop
Cable Management
Integrated cable management
13"-27"
Tilt
-45° to 45°
Pan
-45° to 45°
Rotation
360°
Adjustments
Max Load Weight
10 kg
Stackable
Limited warranty - 5 years
StarTech.com Vertical Dual Monitor Mount Bundle deal on StarTech.com Vertical Dual Monitor Mount
£160.02
Price Range Ex VAT: 50 - 100
