Save workspace and increase productivity by mounting two monitors, stacked, above your desk. This sturdy and sleek dual-monitor mount raises two displays off the surface of your desk or table, to save space while increasing your productivity. With its steel construction, the dual-monitor mount attaches easily to your desk or table to securely hold two monitors, each up to 27", stacked vertically.
The dual-monitor mount holds two displays, one above the other, in a vertical configuration. The height of the monitors can be adjusted, as required, along the 27.5" (700 mm) pole.
With the dual-monitor mount, you can work more comfortably, reducing neck and eye strain without having to look side to side when comparing files or reviewing reference material on your screens. It's ideal for numerous applications including web design, coding, creating and reviewing files, and many others. The monitor mount saves valuable desk space and lets you work clutter-free, which is a welcome addition in numerous office environments including business, healthcare, and financial settings.
The monitor mount enables smooth, effortless +45°/-45° tilt and +45°/-45° swivel, making it easy to reduce glare and find the perfect viewing angle. It can also rotate a full 360° giving you flexible viewing options.
The heavy-duty steel monitor mount holds your two monitors securely in place to protect your investment, and provide long-lasting performance. The dual-monitor mount supports two displays 13" to 27" (330 to 686 mm) in size and 22.1 lb. (10 kg) in weight per monitor. The surface finish features a powder coating to help resist scratches.
The dual-monitor mount makes it easy to mount your VESA mount compatible displays above your desk, table or other surfaces, using the included C-clamp or grommet mount. For easier mounting, the VESA mount features notches that let you pre-set the mounting screw, then slide the monitor into place and tighten the screw. To help keep your work area free of clutter, the monitor mount also features cable clips that keep your cables neatly out of sight.
Adjustable design
Designed to pivot and rotate, this monitor arm allows for optimal positioning with a full 360° rotation, -45° to 45° tilt, and -45° to 45° pan, catering to individual viewing preferences. -
Sturdy construction
Constructed from heavy-duty steel, this mount ensures long-lasting support and stability for dual monitors, making it a reliable choice for busy work environments. -
Space-saving solution
By elevating monitors off the desk, the vertical arm maximizes available desktop space, allowing for improved organization and productivity. -
Customizable mounting options
The mount can be installed using a desk clamp or grommet hole, providing versatility for different work environments and setups. -
Neat cable management
Integrated cable management features help prevent tangles and keep cables organized, promoting a cleaner workspace and reducing distractions.
- StarTech.com Vertical Desk Mount Dual Monitor Arm - For Monitors 13" to 27" - Adjustable - Desk Clamp / Grommet-Hole Mount - Dual VESA Monitors - Black (ARMDUALV) mounting kit - for 2 monitors - black
- Product Type
- Mounting kit - desktop, desk-mountable
- 11.6 cm x 12 cm x 90 cm
- Tilt
- -45° to 45°
- Pan
- -45° to 45°
- Rotation
- 360°
- Adjustments
- Tilt, swivel, rotation
- Recommended Use
- 2 monitors
- Recommended Display Size
- 13"-27"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 10 kg
- Material
- Heavy duty steel
- Black
- Package Content
- Mounting hardware
- 5-year warranty
- Designed For
- P/N: DK30A2DH, DK30C2DAGPD, DK30C2HAGPD, TB3DK2DPM2, TB3DK2DPPD, USB3SDOCKDD, USB3SDOCKHD, USB3SDOCKHDV
- 11.6 cm
- 12 cm
- 90 cm
- Material
- Heavy duty steel
- Black
- Package Content
- Mounting hardware
AV Furniture
- Mounting kit
- Recommended Use
- 2 monitors
- Placing / Mounting
- Desktop, desk-mountable
- Cable Management
- Integrated cable management
- 13"-27"
- Tilt
- -45° to 45°
- Pan
- -45° to 45°
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 10 kg
- Stackable
- Limited warranty - 5 years
- Designed For
StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio | In Stock | £56.02 |
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £139.14 |
StarTech.com Monitor Mount - USB Passthrough | In Stock | £161.64 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £217.58 |
StarTech.com Thin Client Mount - VESA | In Stock | £23.04 |
StarTech.com Under Desk Keyboard Tray | In Stock | £53.36 |
StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors | In Stock | £191.88 |
StarTech.com Desk Mount Dual Monitor Arm - Crossbar | In Stock | £98.86 |
StarTech.com Desk Mount Dual Monitor Arm - Dual Swivel Articulating | In Stock | £97.96 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £54.54 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £61.12 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £77.54 |
StarTech.com Dual Desk Mount Monitor Arm - Built-in 2-port USB and 3.5 mm | In Stock | £191.34 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.52 |
