StarTech.com Vented 1U Rack Shelf - 16 in.
Quicklinx: CX8PWS00 Mfr#: CABSHELF116V
26 In Stock
£30.58 ex VAT
£36.69 inc VAT
This 1U rack shelf lets you add 16 in. of flat storage space to any EIA-310 compliant server rack or cabinet. The shelf is vented to improve air flow and help lower temperatures in your rack.
The durable fixed-rack shelf can hold up to 20 kg (44 lbs.) of equipment and is constructed using SPCC commercial-grade cold-rolled steel.
The 1U cantilever shelf lets you optimize your working space by giving you the ability to mount equipment to your rack instead of taking up desk or floor space. It's perfect for your SOHO (small office, home office) environment, server room or any other location with limited space available.
You can install the 1U vented rack shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable or storing your tools.
  • Ensure your equipment is secure
  • Make the most of your available space
  • Customize your setup
    You can install the 1U vented rack shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable or storing your tools. The CABSHELF116V is backed by a StarTech.com lifetime warranty and free lifetime technical support.
StarTech.com 1U Vented Server Rack Cabinet Shelf, 16in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure w/ Cage Nuts & Screws, 44lbs Weight Capacity - 1U Network Rack Shelf (CABSHELF116V) - rack shelf - 1U
Rack shelf
Package Content
4 cage nuts, 4 mounting screws
Rack Size
16"
Height (Rack Units)
1U
Product Material
Cold-rolled steel
48.26 cm x 40.64 cm x 4.45 cm
Vented, cantilever
P/N: CABSHELF116
Rack shelf
Product Material
Cold-rolled steel
Package Content
Rack Size
16"
Height (Rack Units)
1U
48.26 cm
40.64 cm
4.45 cm
Weight Limit
20 kg
Mounting Kit
Included
Vented, cantilever
P/N: CABSHELF116
CX8P StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £11.90
CX8P StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.44
CX8P StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £29.96
CX8P StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.09
CX8P StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £27.55
CX8P StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £52.23
CX8P StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
CX8P StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £71.34
CX8P StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £79.75
CX8P StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.31
CX8P StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £50.11
CX8P StarTech.com Vented 1U Rack Shelf - 7in In Stock £23.79
CX8P StarTech.com 1U Rack Shelf - 10in In Stock £24.16
CX8P StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £30.58
CX8P StarTech.com Vented 1U Rack Shelf - 10in In Stock £20.23
CX8P StarTech.com 100ft. Hook and Loop Roll - Blue - Reusable In Stock £17.51
CX8P StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £38.79
CX8P StarTech.com 2-Pack 1U Rack Shelf, Vented In Stock £54.63
