StarTech.com Vented 1U Rack Shelf - 10in
Quicklinx: CX8QWS00 Mfr#: CABSHELFV1U
29 In Stock
£21.05 ex VAT
£25.26 inc VAT
This 1U rack shelf lets you add 10 in. of flat storage space to any EIA-310 compliant server rack or cabinet. The shelf is vented to improve air flow and help lower temperatures in your rack.
The durable fixed-rack shelf can hold up to 20 kg (44 lbs.) of equipment and is constructed using SPCC commercial-grade cold-rolled steel.
The 1U cantilever shelf lets you optimize your working space by giving you the ability to mount equipment to your rack instead of taking up desk or floor space. It's perfect for your SOHO (small office, home office) environment, server room or any other location with limited space available.
You can install the 1U vented rack shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable or storing your tools.
  • Ensure your equipment is secure
  • Make the most of your available space
  • Customize your setup
    You can install the 1U vented rack shelf in your rack at any height, giving you a stable surface for placing equipment that's un-mountable or storing your tools. The CABSHELFV1U is backed by a StarTech.com lifetime warranty and free lifetime technical support.
StarTech.com 1U Vented Server Rack Cabinet Shelf, 10in Deep Fixed Cantilever Tray, Rackmount Shelf for 19" AV/Data/Network Equipment Enclosure with Cage Nuts & Screws, 44lbs Weight Cap. - 1U Network Rack Shelf (CABSHELFV1U) - rack shelf - 1U
Rack shelf
Package Content
4 cage nuts, 4 mounting screws
Rack Size
10"
Height (Rack Units)
1U
Product Material
Cold-rolled steel
48.26 cm x 25.4 cm x 4.45 cm
Vented, cantilever
Rack shelf
Product Material
Cold-rolled steel
Package Content
Rack Size
10"
Height (Rack Units)
1U
48.26 cm
25.4 cm
4.45 cm
Weight Limit
20 kg
Mounting Kit
Included
Vented, cantilever
CX8Q StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
CX8Q StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £32.14
CX8Q StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.75
CX8Q StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
CX8Q StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
CX8Q StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £74.28
CX8Q StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £83.04
CX8Q StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £55.64
CX8Q StarTech.com 1U Rack Shelf - 10in In Stock £25.16
CX8Q StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £31.83
