This USB-C Multiport Adapter with DP 1.4 Alt Mode supports 4K 60Hz HDMI (HDR) and turns your MacBook, Dell XPS, or other USB-C laptop or tablet into a workstation, anywhere you go. The USB Type-C Multiport Adapter features a 4K HDMI video output, three USB 3.2 Gen 1 Type-A (5Gbps) ports, SD and MicroSD card readers and a Gigabit Ethernet port, all through one connection to your laptop's USB-C, USB4, or Thunderbolt 3/4 port. Plus, it offers advanced charging and flexibility through a shared USB-C Power Delivery 3.0 and Data port which can be used to connect peripherals, with USB 2.0 transfer speeds (480Mbps), when a power source is not connected. The Multiport Adapter features an extra-long attached 12-inch (30 cm) host cable - for an extended reach, to offer more set up flexibility.
Enhance Productivity
The portable docking station enables you to connect a 4K 60Hz HDMI monitor (4096 x 2160p), or an ultrawide monitor, to your laptop, to create a powerful workstation. -
Connect Your Devices
The USB-C to USB 3.2 Gen 1 hub features three USB-A (5Gbps) ports for connecting your USB devices. -
Multiple Use Cases
A versatile dock solution for use at your office desk, home office, hotel desk, or in the boardroom, and is portable enough to be carried in your bag or backpack for mobile use. This lightweight USB-C Adapter can operate with bus-power alone, or use the USB-C port to connect a USB-C power adapter for laptop charging. Alternatively, use the USB-C port to connect additional peripherals at USB 2.0 speeds. -
Built-In SD and MicroSD Card Readers
Access your multimedia content with ease. The Multiport Adapter provides direct access to your SD, SDHC and SDXC memory cards or microSD (uSD) cards. -
Charge Your Laptop
With support for USB Power Delivery 3.0 pass through (up to 100W), the USB Type-C Multiport Adapter allows you to power and charge your laptop, when connected to a USB-C power source. PD 3.0 features Fast Role Swap (FRS) to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
- StarTech.com USB C Multiport Adapter, 4K 60Hz HDMI Video, 3 Pt 5Gbps USB-A Hub, 100W Power Delivery Pass-Through, GbE, SD/MicroSD, USB Type-C Mini Travel Dock, 12" / 30cm Cable - USB C Laptop Docking Station - docking station - USB-C / Thunderbolt 3 / Thunderbolt 4 - HDMI - 1GbE
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- HDMI
- 11.2 cm x 5 cm x 1.2 cm
- 75 g
- Space grey
- Networking
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Docking station
- 11.2 cm
- 5 cm
- 1.2 cm
- 75 g
- Enclosure Colour
- Space grey
Video
- Max Resolution Details
- 4096 x 2160 - 60 Hz
- Data Link Protocol
- USB 2.0, USB 3.0, USB 3.1 Gen 1, USB4, IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Expansion Slots
- 1 (total) / 1 (free) x SD Memory Card , 1 (total) / 1 (free) x microSD
- 1 x display / video - HDMI - 19 pin HDMI Type A , 3 x USB-C 3.2 Gen 1 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C
- Input Device
- SD card reader, microSD card reader
- Cables Included
- 1 x USB-C cable - integrated - 30 cm
- 100W power delivery, UASP transfer protocol, Preboot Execution Environment (PXE) support, HDR10 support, HDR support, DisplayPort Alt Mode, full duplex support, portable
- Plug and Play, DisplayPort 1.4, USB Power Delivery 3.0, FCC, RoHS, WEEE
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple MacOS X 10.11 - 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Apple iPadOS, Android, Linux 3.5.x or later LTS versions only, Google Chrome OS
- Limited warranty - 3 years
- Shipping Width
- 17 cm
- Shipping Depth
- 14.2 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 200 g
- 0 °C
- 70 °C
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.92 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £9.71 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.32 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £16.00 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £12.98 |
StarTech.com USB C Multiport Adapter 2 HDMI | In Stock | £65.89 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £30.58 |
StarTech.com USB-C Multiport Adapter | In Stock | £22.01 |
StarTech.com USB C Multiport Adapter | In Stock | £84.39 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £28.98 |
StarTech.com USB-C Multiport Adapter, HDMI | In Stock | £25.65 |
StarTech.com USB-C Multiport Adapter - HDMI/DP | In Stock | £43.75 |
StarTech.com USB-C Multiport Adapter - HDMI/VGA | In Stock | £27.87 |
StarTech.com USB-C Speakerphone Dock | In Stock | £79.25 |
StarTech.com USB-C Triple-Monitor Adapter | In Stock | £78.42 |
StarTech.com USB-C/USB-A Multiport Adapter | In Stock | £47.68 |
StarTech.com USB-C Triple-Monitor Adapter | In Stock | £82.13 |
