StarTech.com USBC Multiport Adapter 4K 60Hz
Quicklinx: GVKKWS00 Mfr#: 127B-USBC-MULTIPORT
Device Type: Laptop, Macbook, Other, Tablet
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Space grey
More than 50 In Stock
£31.88 ex VAT
£38.25 inc VAT
This USB-C Multiport Adapter with DP 1.4 Alt Mode supports 4K 60Hz HDMI (HDR) and turns your MacBook, Dell XPS, or other USB-C laptop or tablet into a workstation, anywhere you go. The USB Type-C Multiport Adapter features one 4K HDMI video output, three USB 3.2 Gen 1 Type-A (5Gbps) ports, and a Gigabit Ethernet port, all through one connection to your laptop's USB-C, USB4, or Thunderbolt 3/4 port. In addition, it offers advanced charging and flexibility through a shared USB-C Power Delivery 3.0 and Data port; this port can be used to connect peripherals, whenever a power source is not connected, at USB 2.0 data transfer speeds (480Mbps). The Multiport Adapter features an extra-long attached 12-inch (30 cm) host cable - for an extended reach, to offer more setup flexibility.
  • Enhance Productivity
    The portable docking station enables the connection of a 4K 60Hz HDMI monitor (4096 x 2160p), or an ultrawide monitor, to your laptop, in order to create a powerful workstation.
  • Connect Your USB Devices
    The USB-C to USB 3.2 Gen 1 hub features three USB-A (5Gbps) ports for connecting your USB devices.
  • Multiple Use Cases
    A versatile dock solution for use at your office desk, home office, hotel desk, or in the boardroom, it is portable enough to be carried in your bag or backpack for mobile use. This lightweight USB-C Adapter can be bus-powered. Alternatively, connect your laptop's USB-C power adapter to charge your laptop and USB peripherals.
  • Charge Your Laptop
    With support for USB Power Delivery 3.0 pass through (up to 100W), the USB Type-C Multiport Adapter allows you to power and charge your laptop, when connected to a USB-C power source. PD 3.0 features Fast Role Swap (FRS) to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power).
  • Reliable Network Connectivity
    The Gigabit Ethernet port ensures reliable wired network access, with support for PXE Boot and WoL.
StarTech.com USB C Multiport Adapter, 4K 60Hz HDMI Video, 3-Port 5Gbps USB-A 3.2 Hub, 100W Power Delivery Passthrough, GbE, USB Type-C Mini Travel Dock with Charging, 12in/30cm Cable - USB C Laptop Docking Station (127B-USBC-MULTIPORT) - docking station - USB-C - 1GbE
Docking station
Docking Interface
USB-C
5 cm x 1.2 cm
70 g
Space grey
Gigabit Ethernet
3-year warranty
Docking station
5 cm
1.2 cm
70 g
Enclosure Colour
Space grey
Video
Max Resolution Details
4096 x 2160 - 60 Hz
USB 3.2 Gen 1, USB 3.1 Gen 1, USB 2.0, Power Delivery 3.0, IEEE 802.3, IEEE 802.3ab, IEEE 802.3u
1 x display / video - HDMI - 19 pin HDMI Type A , 3 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB-C with Power Delivery (85 W) - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C 3.2 Gen 1 - 24 pin USB-C
1 x USB-C cable - integrated - 30 cm
100W power delivery (pass-through), HDR10 support, DisplayPort Alt Mode, Fast Role Swap, wake on LAN, Preboot Execution Environment (PXE) support, LED indicator, full duplex support
Thunderbolt 4, Thunderbolt 3, DisplayPort 1.2, DisplayPort 1.4, UASP (USB Attached SCSI Protocol), FCC
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Apple macOS Monterey 12.0, Apple macOS 13.0, Apple iPadOS, Android, Linux 3.5.x - 5.15.x LTS versions only, Google Chrome OS
Limited warranty - 3 years
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
200 g
70 °C
GVKK StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.63
GVKK StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £9.00
GVKK StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.72
GVKK StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.34
GVKK StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.86
GVKK StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £15.46
GVKK StarTech.com USBC Multiport Adapter 4K 60Hz In Stock £45.76
GVKK StarTech.com USB-C Multiport Adapter 4K60Hz In Stock £38.62
GVKK StarTech.com 4-Port USB-C Hub, 5Gbps, PD In Stock £41.59
GVKK StarTech.com USB-C Triple Monitor Docking Station In Stock £179.82
Device Type: Laptop
Device Type: Macbook
Device Type: Other
Device Type: Tablet
Colour: Space grey
