This USB-C Multiport Adapter with DP 1.4 Alt Mode supports 4K 60Hz HDMI (HDR) and turns your MacBook, Dell XPS, or other USB-C laptop or tablet into a workstation, anywhere you go. The USB Type-C Multiport Adapter features one 4K HDMI video output, three USB 3.2 Gen 1 Type-A (5Gbps) ports, and a Gigabit Ethernet port, all through one connection to your laptop's USB-C, USB4, or Thunderbolt 3/4 port. In addition, it offers advanced charging and flexibility through a shared USB-C Power Delivery 3.0 and Data port; this port can be used to connect peripherals, whenever a power source is not connected, at USB 2.0 data transfer speeds (480Mbps). The Multiport Adapter features an extra-long attached 12-inch (30 cm) host cable - for an extended reach, to offer more setup flexibility.
Enhance Productivity
The portable docking station enables the connection of a 4K 60Hz HDMI monitor (4096 x 2160p), or an ultrawide monitor, to your laptop, in order to create a powerful workstation. -
Connect Your USB Devices
The USB-C to USB 3.2 Gen 1 hub features three USB-A (5Gbps) ports for connecting your USB devices. -
Multiple Use Cases
A versatile dock solution for use at your office desk, home office, hotel desk, or in the boardroom, it is portable enough to be carried in your bag or backpack for mobile use. This lightweight USB-C Adapter can be bus-powered. Alternatively, connect your laptop's USB-C power adapter to charge your laptop and USB peripherals. -
Charge Your Laptop
With support for USB Power Delivery 3.0 pass through (up to 100W), the USB Type-C Multiport Adapter allows you to power and charge your laptop, when connected to a USB-C power source. PD 3.0 features Fast Role Swap (FRS) to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power). -
Reliable Network Connectivity
The Gigabit Ethernet port ensures reliable wired network access, with support for PXE Boot and WoL.
- StarTech.com USB C Multiport Adapter, 4K 60Hz HDMI Video, 3-Port 5Gbps USB-A 3.2 Hub, 100W Power Delivery Passthrough, GbE, USB Type-C Mini Travel Dock with Charging, 12in/30cm Cable - USB C Laptop Docking Station (127B-USBC-MULTIPORT) - docking station - USB-C - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- 5 cm x 1.2 cm
- 70 g
- Space grey
- Networking
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Docking station
- 5 cm
- 1.2 cm
- 70 g
- Enclosure Colour
- Space grey
Video
- Max Resolution Details
- 4096 x 2160 - 60 Hz
- Data Link Protocol
- USB 3.2 Gen 1, USB 3.1 Gen 1, USB 2.0, Power Delivery 3.0, IEEE 802.3, IEEE 802.3ab, IEEE 802.3u
- 1 x display / video - HDMI - 19 pin HDMI Type A , 3 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x USB-C with Power Delivery (85 W) - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C 3.2 Gen 1 - 24 pin USB-C
- Cables Included
- 1 x USB-C cable - integrated - 30 cm
- 100W power delivery (pass-through), HDR10 support, DisplayPort Alt Mode, Fast Role Swap, wake on LAN, Preboot Execution Environment (PXE) support, LED indicator, full duplex support
- Thunderbolt 4, Thunderbolt 3, DisplayPort 1.2, DisplayPort 1.4, UASP (USB Attached SCSI Protocol), FCC
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Apple macOS Monterey 12.0, Apple macOS 13.0, Apple iPadOS, Android, Linux 3.5.x - 5.15.x LTS versions only, Google Chrome OS
- Limited warranty - 3 years
- Shipping Width
- 17 cm
- Shipping Depth
- 14.2 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 200 g
- 0 °C
- 70 °C
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £9.63 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £9.00 |
StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female | In Stock | £9.72 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £11.34 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.86 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £15.46 |
StarTech.com USBC Multiport Adapter 4K 60Hz | In Stock | £45.76 |
StarTech.com USB-C Multiport Adapter 4K60Hz | In Stock | £38.62 |
StarTech.com 4-Port USB-C Hub, 5Gbps, PD | In Stock | £41.59 |
StarTech.com USB-C Triple Monitor Docking Station | In Stock | £147.15 |
