Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
StarTech.com USB4 M.2 NVMe Enclosure, USB-C
Quicklinx: J9X0WS00 Mfr#: 1USB4-NVME-ENCLOSURE
34 In Stock
£85.08 ex VAT
£102.09 inc VAT
The StarTech.com 1USB4-NVME-ENCLOSURE is a storage enclosure designed for M.2 NGFF drives with PCI Express 4.0 x 4 interface. This device supports a variety of form factors including 2230, 2242, 2260, and 2280, allowing for compatibility with different M.2 SSDs. It offers data transfer rates of up to 3800 MB/s, ensuring access to your data, whether for storage expansion or backup solutions.
Constructed with aluminum housing for durability, this enclosure integrates an LED indicator for monitoring of drive activity. Bus powered for convenience and featuring S.M.A.R.T. support along with TRIM functionality, the enclosure maintains drive health. With a USB-C connection type and support for USB4 and Thunderbolt 5, it provides an interface for high-speed data transfer in computing environments.
StarTech.com - storage enclosure
Storage enclosure
1 (max)
Supported Drives
PCIe 4.0 x 4 (NVMe)
Storage Controller
(PCI Express 4.0 x 4 (NVMe))
6.5 cm x 12.48 cm x 2.88 cm
340 g
Storage enclosure
Enclosure Colour
Chassis
Supported Devices / Modules Qty
1
Supported Drives
PCIe 4.0 x 4 (NVMe)
CPU
1 x ASMedia ASM2464PD
Storage Controller
(USB4 / Thunderbolt 5)
Interface Type
Data Transfer Rate
40 GBps
Expansion Bays
1 (total) / 1 (free) x internal - M.2 NGFF 2230/2242/2260/2280
1 x USB4 / Thunderbolt 5 - 24 pin USB-C
Aluminium housing, LED indicator, TRIM support, 4Kn drive compatible, S.M.A.R.T. support, bus powered, up to 3800MB/s performance, silicone feet
1 x USB-C cable - 30 cm
MTBF
112,000 hours
RoHS, FCC, WEEE, RCM, UASP (USB Attached SCSI Protocol)
Thermal pad, philips head screwdriver
6.5 cm
12.48 cm
2.88 cm
340 g
Shipping Width
11.4 cm
Shipping Depth
19 cm
Shipping Height
3.5 cm
Shipping Weight
430 kg
Up to 90% RH
