The StarTech.com 1USB4-NVME-ENCLOSURE is a storage enclosure designed for M.2 NGFF drives with PCI Express 4.0 x 4 interface. This device supports a variety of form factors including 2230, 2242, 2260, and 2280, allowing for compatibility with different M.2 SSDs. It offers data transfer rates of up to 3800 MB/s, ensuring access to your data, whether for storage expansion or backup solutions.
Constructed with aluminum housing for durability, this enclosure integrates an LED indicator for monitoring of drive activity. Bus powered for convenience and featuring S.M.A.R.T. support along with TRIM functionality, the enclosure maintains drive health. With a USB-C connection type and support for USB4 and Thunderbolt 5, it provides an interface for high-speed data transfer in computing environments.
 - StarTech.com - storage enclosure
 - Storage enclosure
 - Black
- Installed Devices / Modules Qty
 - 1 (max)
- Supported Drives
 - PCIe 4.0 x 4 (NVMe)
- Storage Controller
 - (PCI Express 4.0 x 4 (NVMe))
 - 6.5 cm x 12.48 cm x 2.88 cm
 - 340 g
 - 2-year warranty
 - Storage enclosure
- Enclosure Colour
 - Black
Chassis
- Supported Devices / Modules Qty
 - 1
- Supported Drives
- CPU
 - 1 x ASMedia ASM2464PD
Storage Controller
 - (USB4 / Thunderbolt 5)
- Interface Type
 - PCI Express 4.0 x 4 (NVMe)
- Data Transfer Rate
 - 40 GBps
- Expansion Bays
 - 1 (total) / 1 (free) x internal - M.2 NGFF 2230/2242/2260/2280
 - 1 x USB4 / Thunderbolt 5 - 24 pin USB-C
 - Aluminium housing, LED indicator, TRIM support, 4Kn drive compatible, S.M.A.R.T. support, bus powered, up to 3800MB/s performance, silicone feet
- Cables Included
 - 1 x USB-C cable - 30 cm
- MTBF
 - 112,000 hours
 - RoHS, FCC, WEEE, RCM, UASP (USB Attached SCSI Protocol)
- Included Accessories
 - Thermal pad, philips head screwdriver
 - 6.5 cm
 - 12.48 cm
 - 2.88 cm
 - 340 g
- Shipping Width
 - 11.4 cm
- Shipping Depth
 - 19 cm
- Shipping Height
 - 3.5 cm
- Shipping Weight
 - 430 kg
 - Limited warranty - 2 years
 - 0 °C
 - 40 °C
 - Up to 90% RH
