This USB VGA KVM console extender lets you control a server, computer or multiple computers (connected through KVM switch) over a standard Cat5 or Cat6 UTP network cable connection, at distances of up to 500ft away. PC connection cables are included with this product for a ready out of the box solution.
You can use your existing keyboard, mouse, and monitor to access both the server room and your office computer, saving space and avoiding the need for a dedicated remote console by allowing you to switch between workstation view and KVM view at the remote location.
The USB VGA console extender is designed to provide long lasting, reliable operation.
- StarTech.com USB VGA KVM Console Extender over CAT5 UTP - KVM extender
- KVM extender
- Form Factor
- External
- Localisation
- United Kingdom
- Max Transfer Distance
- 150 m
- 15.5 cm x 7.5 cm x 2 cm
- 299 g
- 2-year warranty
- KVM extender
- Form Factor
- External
- Black
- Localisation
- United Kingdom
- Connectivity Technology
- Wired
- Max Resolution
- 1024 x 768
- 150 m
- 1 x USB mouse , 1 x USB keyboard , 1 x VGA - HD-15 , 1 x KVM - HD-15
- Cables Included
- 2 x keyboard / mouse / video cable
- FCC, RoHS
- Power Device
- External power adapter
- 15.5 cm
- 7.5 cm
- 2 cm
- 299 g
- Limited warranty - 2 years
StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable | In Stock | £6.74 |
StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable | In Stock | £9.75 |
StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable | In Stock | £14.24 |
