StarTech.com USB Type-C Ethernet Adapter
Quicklinx: J1M3WS00 Mfr#: U2GA-USB-C-ETHERNET
18 In Stock
£22.24 ex VAT
£26.68 inc VAT
The StarTech.com 2.5GbE USB-C to Ethernet Adapter with USB-A Converter offers a seamless networking solution for enhanced connectivity. This external network adapter features a cable length of 15.2 cm and supports multiple data link protocols, including 2.5 Gigabit Ethernet, ensuring high-speed data transfer rates of up to 2.5 Gbps. With its integrated design, this adapter is USB-powered and works as a Plug-and-Play device, making it easy to connect to various systems.
Designed for versatility, the adapter is compatible with Thunderbolt 3 and provides a variety of network connectivity options with support for Jumbo frame sizes up to 16,000 bytes. The operating temperature range is between 0°C to 45°C, and it operates efficiently in humid environments with 10% to 85% RH. This adapter also features status indicators for link/activity and speed, ensuring users can monitor their connection status effortlessly.
  • Efficient Connectivity
    Equipped with USB-C 3.2 Gen 1 technology and a female RJ-45 connector, this adapter ensures reliable wired network connections, accommodating various Ethernet types including 10M/100M/1G/2.5 Gigabit Ethernet.
  • Robust Performance
    With an MTBF of 1,612,526 hours, users can expect durable performance, perfect for high-demand networking scenarios.
  • Versatile Compatibility
    This adapter is compliant with multiple standards such as FCC, RoHS, and RCM, making it a suitable choice for diverse environments and regulatory requirements.
  • Enhanced Features
    Features like Wake On LAN, VLAN tagging, and auto-negotiation provide flexibility and improve overall network management capabilities.
  • User-Friendly Design
    The external form factor ensures easy installation and portability, while the status indicators allow for quick monitoring of connection and speed.
StarTech.com 2.5GbE USB-C to Ethernet Adapter with USB-A Converter - network adapter - USB-C 3.2 Gen 1 / Thunderbolt 3 - 10M/100M/1G/2.5 Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
Ports
2.2 cm x 1.5 cm
26 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Data Transfer Rate
2.5 Gbps
Jumbo frame size: 16000
Realtek Semiconductor RTL8156BG
IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3i, IEEE 802.3u, IEEE 802.3x, IEEE 802.3bz
Space grey
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2008 R2 / 2012 R2 / 2016 / 2022, Windows 10 (on ARM), Windows 11 (on ARM), Linux Kernel 2.4.20 or later (LTS versions only), Apple MacOS X 10.11 - 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Apple macOS Sonoma 14.0, Google Chrome OS, Apple iOS
Network adapter
External
Ports
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
2.5 Gbps
Status Indicators
Link/activity, speed
Auto-uplink (auto MDI/MDI-X), VLAN Tagging, WOL, PXE support, full duplex mode, promiscuous mode, USB powered, Thunderbolt compatible, auto-negotiation
Processor / Memory
1 x 2.5Gb Ethernet - RJ-45 - female
1 x USB-C cable (integrated) - 15.2 cm , 1 x USB-C to USB-A adapter (external)
MTBF
1,612,526 hours
RoHS, WEEE, FCC, RCM
Space grey
2.2 cm
1.5 cm
26 g
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
1.4 cm
Shipping Weight
28 g
45 °C
10 - 85% RH (non-condensing)
J1M3 StarTech.com USB-C to Ethernet Adapter In Stock £22.53
Wired / Wireless: Wired
Protocol: Fast Ethernet
Protocol: Ethernet
Protocol: Gigabit Ethernet
Protocol: 2.5 Gigabit Ethernet
Type: Network adapter
