The StarTech.com 2.5GbE USB-C to Ethernet Adapter with USB-A Converter offers a seamless networking solution for enhanced connectivity. This external network adapter features a cable length of 15.2 cm and supports multiple data link protocols, including 2.5 Gigabit Ethernet, ensuring high-speed data transfer rates of up to 2.5 Gbps. With its integrated design, this adapter is USB-powered and works as a Plug-and-Play device, making it easy to connect to various systems.
Designed for versatility, the adapter is compatible with Thunderbolt 3 and provides a variety of network connectivity options with support for Jumbo frame sizes up to 16,000 bytes. The operating temperature range is between 0°C to 45°C, and it operates efficiently in humid environments with 10% to 85% RH. This adapter also features status indicators for link/activity and speed, ensuring users can monitor their connection status effortlessly.
Efficient Connectivity
Equipped with USB-C 3.2 Gen 1 technology and a female RJ-45 connector, this adapter ensures reliable wired network connections, accommodating various Ethernet types including 10M/100M/1G/2.5 Gigabit Ethernet. -
Robust Performance
With an MTBF of 1,612,526 hours, users can expect durable performance, perfect for high-demand networking scenarios. -
Versatile Compatibility
This adapter is compliant with multiple standards such as FCC, RoHS, and RCM, making it a suitable choice for diverse environments and regulatory requirements. -
Enhanced Features
Features like Wake On LAN, VLAN tagging, and auto-negotiation provide flexibility and improve overall network management capabilities. -
User-Friendly Design
The external form factor ensures easy installation and portability, while the status indicators allow for quick monitoring of connection and speed.
- StarTech.com 2.5GbE USB-C to Ethernet Adapter with USB-A Converter - network adapter - USB-C 3.2 Gen 1 / Thunderbolt 3 - 10M/100M/1G/2.5 Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- Ports
- 2.2 cm x 1.5 cm
- 26 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
- Data Transfer Rate
- 2.5 Gbps
- Capacity
- Jumbo frame size: 16000
- Processor
- Realtek Semiconductor RTL8156BG
- IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3i, IEEE 802.3u, IEEE 802.3x, IEEE 802.3bz
- Space grey
- System Requirements
- Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2008 R2 / 2012 R2 / 2016 / 2022, Windows 10 (on ARM), Windows 11 (on ARM), Linux Kernel 2.4.20 or later (LTS versions only), Apple MacOS X 10.11 - 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Apple macOS Sonoma 14.0, Google Chrome OS, Apple iOS
- 2-year warranty
- Network adapter
- Form Factor
- External
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
- 2.5 Gbps
- Capacity
- Status Indicators
- Link/activity, speed
- Auto-uplink (auto MDI/MDI-X), VLAN Tagging, WOL, PXE support, full duplex mode, promiscuous mode, USB powered, Thunderbolt compatible, auto-negotiation
Processor / Memory
- Processor
- 1 x 2.5Gb Ethernet - RJ-45 - female
- Cables Included
- 1 x USB-C cable (integrated) - 15.2 cm , 1 x USB-C to USB-A adapter (external)
- MTBF
- 1,612,526 hours
- RoHS, WEEE, FCC, RCM
- Space grey
- OS Required
- 2.2 cm
- 1.5 cm
- 26 g
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 1.4 cm
- Shipping Weight
- 28 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 85% RH (non-condensing)
StarTech.com USB-C to Ethernet Adapter | In Stock | £21.76 |
