StarTech.com USB Type-C Ethernet Adapter
Quicklinx: J1LYWS00 Mfr#: C22G-USB-ETHERNET
More than 50 In Stock
£22.40 ex VAT
£26.88 inc VAT
The 2.5GbE USB-C to Ethernet Adapter by StarTech.com provides a reliable and efficient way to connect to wired networks with ease. This adapter supports data transfer rates of up to 2.5 Gbps, making it suitable for high-speed Internet connections. Designed with an integrated USB-C cable that is 15.2 cm long, it is compact and easy to use, allowing for seamless connectivity with compatible devices. The device features an RJ-45 female connector, making it compatible with various Ethernet types, including 2.5GBase-T and Gigabit Ethernet.
Equipped with impressive specifications, this network adapter supports Jumbo frame sizes of up to 16,000, enhancing network performance. It's built to withstand a range of environmental conditions, operating between 0°C and 45°C and within a humidity range of 10 - 85% RH, ensuring robust performance under various scenarios. Additionally, this adapter is compliant with multiple standards, including FCC, RoHS, and WEEE, affirming its adherence to safety and environmental regulations, making it a reliable choice for networking needs.
  • High-performance connectivity
    This adapter delivers data transfer rates of 2.5 Gbps, ensuring fast and reliable connections for demanding applications. It supports multiple data link protocols, including Ethernet and Fast Ethernet.
  • Robust design for durability
    Built to operate in temperatures ranging from 0°C to 45°C, this adapter is designed to withstand various environmental conditions, making it suitable for different networking scenarios.
  • Versatile compatibility
    Equipped with an RJ-45 connector, this adapter can connect to different Ethernet standards, such as 10M, 100M, 1G, and 2.5G, providing users with flexibility for their networking needs.
  • User-friendly features
    The adapter supports auto-negotiation and features Wake On LAN (WOL) capabilities, enhancing usability and ensuring efficient operations for end-users.
  • Standards compliant
    This product meets several compliance standards, including FCC, RoHS, and WEEE, ensuring it adheres to safety and environmental regulations for peace of mind.
StarTech.com 2.5GbE USB-C to Ethernet Adapter - network adapter - USB-C 3.2 Gen 1 / Thunderbolt 3 - 10M/100M/1G/2.5 Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
Ports
2.2 cm x 1.5 cm
18 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Data Transfer Rate
2.5 Gbps
Jumbo frame size: 16000
Realtek Semiconductor RTL8156BG
IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3i, IEEE 802.3u, IEEE 802.3x, IEEE 802.3bz
Space grey
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2008 R2 / 2012 R2 / 2016 / 2022, Windows 10 (on ARM), Windows 11 (on ARM), Linux Kernel 2.4.20 or later (LTS versions only), Apple MacOS X 10.11 - 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Apple macOS Sonoma 14.0, Google Chrome OS, Apple iOS
Network adapter
External
Ports
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
2.5 Gbps
Status Indicators
Link/activity, speed
Auto-uplink (auto MDI/MDI-X), VLAN Tagging, WOL, PXE support, full duplex mode, promiscuous mode, USB powered, Thunderbolt compatible, auto-negotiation
Processor / Memory
1 x 2.5Gb Ethernet - RJ-45 - female
1 x USB-C cable (integrated) - 15.2 cm
MTBF
1,912,948 hours
RoHS, WEEE, FCC, RCM
Space grey
2.2 cm
1.5 cm
18 g
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
1.6 cm
Shipping Weight
24 g
45 °C
10 - 85% RH (non-condensing)
J1LY StarTech.com USB-C to Ethernet Adapter In Stock £22.53
