StarTech.com USB Type-C Ethernet Adapter
Quicklinx: J1LXWS00 Mfr#: 2GPD3-USB-C-ETHERNET
30 In Stock
£25.69 ex VAT
£30.82 inc VAT
The StarTech.com 2.5GbE USB-C to Ethernet Adapter enhances networking capabilities with its integrated USB-C cable, allowing for easy connection to various devices. With a data transfer rate of 2.5 Gbps, this network adapter is compatible with multiple Ethernet standards, including 2.5 Gigabit Ethernet, ensuring efficient and reliable data communication. With a compact form factor and a length of 15 cm, this adapter is ideal for portable use, while its wide operating temperature range of 0°C to 45°C and humidity resistance of 10 - 85% RH make it suitable for various environments. Its robust design, compliant with FCC and RoHS standards, boasts an MTBF of nearly 2 million hours, providing peace of mind in performance and durability.
  • Robust connectivity options
    The adapter supports 10M, 100M, 1G, and 2.5 Gigabit Ethernet standards, ensuring compatibility with a variety of network setups while providing stable connections.
  • Powerful data handling
    Featuring a jumbo frame size up to 16000, this adapter optimizes data throughput and minimizes delays during large data transfers.
  • Environmentally compliant
    This product adheres to FCC, RoHS, and WEEE standards, reflecting a commitment to eco-friendly practices while maintaining high-quality performance.
  • Advanced features support
    With functionalities such as Wake On LAN, auto-uplink, and PXE support, this adapter facilitates various network management tasks efficiently.
  • Broad compatibility
    Compatible with USB Power Delivery up to 100 watt and Thunderbolt technology, this adapter seamlessly integrates into numerous technology ecosystems.
StarTech.com 2.5GbE USB-C to Ethernet Adapter - network adapter - USB-C 3.2 Gen 1 / Thunderbolt 3 - 10M/100M/1G/2.5 Gigabit Ethernet + USB-C 3.2 Gen 1
Network adapter
External
Interface (Bus) Type
Ports
2.2 cm x 1.5 cm
24.7 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Data Transfer Rate
2.5 Gbps
Jumbo frame size: 16000
Realtek Semiconductor RTL8156BG
IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3i, IEEE 802.3u, IEEE 802.3x, IEEE 802.3bz
Space grey
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2008 R2 / 2012 R2 / 2016 / 2022, Windows 10 (on ARM), Windows 11 (on ARM), Linux Kernel 2.4.20 or later (LTS versions only), Apple MacOS X 10.11 - 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Apple macOS Sonoma 14.0, Google Chrome OS, Apple iOS, Android
Network adapter
External
Ports
Wired
Cabling Type
Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
Data Transfer Rate
2.5 Gbps
Status Indicators
Link/activity, speed
Auto-uplink (auto MDI/MDI-X), VLAN Tagging, WOL, PXE support, full duplex mode, promiscuous mode, USB powered, USB Power Delivery (up to 100 watt), Thunderbolt compatible, auto-negotiation
Processor / Memory
1 x 2.5Gb Ethernet - RJ-45 - female , 1 x USB 3.2 Gen 1 - 24 pin USB-C - female
1 x USB-C cable (integrated) - 15 cm
MTBF
1,912,948 hours
USB Power Delivery 3.0, RoHS, WEEE, FCC, RCM
Space grey
2.2 cm
1.5 cm
24.7 g
Shipping Width
22 cm
Shipping Depth
12.8 cm
Shipping Height
1.6 cm
Shipping Weight
27 g
45 °C
10 - 85% RH (non-condensing)
J1LX StarTech.com USB-C to Ethernet Adapter In Stock £21.91
Wired / Wireless: Wired
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Protocol: Ethernet
Protocol: 2.5 Gigabit Ethernet
Type: Network adapter
