The USB-C to Ethernet Adapter by StarTech.com provides seamless connectivity for devices requiring a reliable wired network connection. It features a compact integrated design with a 15 cm USB-C cable that supports data transfer rates of up to 1 Gbps, ensuring fast and efficient network access. The adapter is built to support various Ethernet protocols, including Gigabit Ethernet and Fast Ethernet, making it an ideal choice for both home and office environments. With support for Wake On LAN (WOL) and USB Power Delivery of up to 100 watts, this adapter combines versatility and efficiency for diverse networking needs.
Efficient connectivity
The adapter features a USB-C 3.2 Gen 1 interface that allows for easy connection with compatible devices, ensuring stable and reliable wired networking capabilities. -
Robust data handling
With a jumbo frame size of 9000 and support for full duplex mode, this adapter enhances data throughput, making it suitable for high-bandwidth tasks and applications. -
Environmental resilience
Designed for operation in a wide temperature range from 0 °C to 45 °C and humidity levels from 10% to 85%, the adapter remains functional in various environmental conditions. -
Versatile compatibility
This adapter is compliant with several standards including FCC and RoHS, and it is compatible with Thunderbolt, ensuring it meets diverse user needs. -
Long-lasting reliability
With an MTBF of nearly 2 million hours, the USB-C to Ethernet Adapter is designed for durability, providing extended service life for everyday networking tasks.
- StarTech.com USB-C to Ethernet Adapter, NIC, 1Gbps - network adapter - USB-C 3.2 Gen 1 - Gigabit Ethernet + USB-C 3.2 Gen 1
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB-C 3.2 Gen 1
- Ports
- 2.2 cm x 1.5 cm
- 24.7 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- Capacity
- Jumbo frame size: 9000
- Processor
- Realtek Semiconductor RTL8153B
- IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3i, IEEE 802.3u, IEEE 802.3x
- Space grey
- System Requirements
- Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2008 R2 / 2012 R2 / 2016 / 2022, Windows 10 (on ARM), Windows 11 (on ARM), Linux Kernel 2.4.20 or later (LTS versions only), Apple MacOS X 10.11 - 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Apple macOS Sonoma 14.0, Google Chrome OS, Apple iOS, Android
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB-C 3.2 Gen 1
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- Capacity
- Status Indicators
- Link/activity, speed
- Auto-uplink (auto MDI/MDI-X), VLAN Tagging, WOL, PXE support, full duplex mode, promiscuous mode, USB powered, USB Power Delivery (up to 100 watt), Thunderbolt compatible
Processor / Memory
- Processor
- 1 x 1000Base-T - RJ-45 - female , 1 x USB 3.2 Gen 1 - 24 pin USB-C - female
- Cables Included
- 1 x USB-C cable (integrated) - 15 cm
- MTBF
- 1,912,948 hours
- USB Power Delivery 3.0, RoHS, WEEE, FCC, RCM
- Space grey
- OS Required
- 2.2 cm
- 1.5 cm
- 24.7 g
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 1.6 cm
- Shipping Weight
- 27 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 85% RH (non-condensing)
StarTech.com USB-C to Ethernet Adapter | In Stock | £22.26 |
