The USB2VGAE3 USB VGA Multi-Monitor External Video Adapter lets you add a high-resolution (1920x1200) external VGA output to your desktop or laptop computer, using an available USB 2.0 port. A cost-effective solution for systems that lack the outputs required for a multi-monitor setup, this high-performance USB to VGA adapter can be used to mirror your primary display and show the same image on both screens, or extend your desktop to double your workspace. This small form factor USB video adapter can be used with up to 4 additional (5 total) USB2VGAE3 USB video adapters, creating multiple VGA connections to add displays quickly and easily - all without having to open the computer case to add extra video cards.
- StarTech.com USB to VGA Adapter - 1920x1200 - External Video & Graphics Card - Dual Monitor Display Adapter - Supports Windows (USB2VGAE3) - USB / VGA adapter - USB to HD-15 (VGA) - TAA Compliant - 50 cm
- USB / VGA adapter
- 1920 x 1200 (WUXGA) support, 32 MB memory
- Length
- 50 cm
- Connector
- 4 pin USB Type A - male (input)
- Connector (Second End)
- 15 pin HD D-Sub (HD-15) - female (output)
- USB / USB 2.0
- Grey
- TAA Compliant
- 2-year warranty
- Designed For
- P/N: MXT101MM
- USB / VGA adapter
- Length
- 50 cm
- Grey
- 5.25 cm
- 8.8 cm
- 1.8 cm
- Connector
- USB / USB 2.0, FCC, RoHS
- TAA Compliant
- Shipping Width
- 14.5 cm
- Shipping Depth
- 21 cm
- Shipping Height
- 4 cm
- Shipping Weight
- 247 g
- 2-year warranty
- Designed For
- P/N: MXT101MM
StarTech.com USB to VGA Multi Monitor External Video Adapter | In Stock | £15.77 |
StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200 | In Stock | £12.18 |
StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter for Mac and PC | In Stock | £24.96 |
StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p | In Stock | £19.49 |
StarTech.com USB 3.0 VGA Video Adapter | In Stock | £17.45 |
