StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200
Quicklinx: 7RXXWS00 Mfr#: USB2VGAE3
24 In Stock
£14.94 ex VAT
£17.92 inc VAT
The USB2VGAE3 USB VGA Multi-Monitor External Video Adapter lets you add a high-resolution (1920x1200) external VGA output to your desktop or laptop computer, using an available USB 2.0 port. A cost-effective solution for systems that lack the outputs required for a multi-monitor setup, this high-performance USB to VGA adapter can be used to mirror your primary display and show the same image on both screens, or extend your desktop to double your workspace. This small form factor USB video adapter can be used with up to 4 additional (5 total) USB2VGAE3 USB video adapters, creating multiple VGA connections to add displays quickly and easily - all without having to open the computer case to add extra video cards.
StarTech.com USB to VGA Adapter - 1920x1200 - External Video & Graphics Card - Dual Monitor Display Adapter - Supports Windows (USB2VGAE3) - USB / VGA adapter - USB to HD-15 (VGA) - TAA Compliant - 50 cm
USB / VGA adapter
1920 x 1200 (WUXGA) support, 32 MB memory
Length
50 cm
Connector
4 pin USB Type A - male (input)
Connector (Second End)
15 pin HD D-Sub (HD-15) - female (output)
USB / USB 2.0
Grey
TAA Compliant
P/N: MXT101MM
USB / VGA adapter
Length
50 cm
Grey
5.25 cm
8.8 cm
1.8 cm
Connector
USB / USB 2.0, FCC, RoHS
TAA Compliant
Shipping Width
14.5 cm
Shipping Depth
21 cm
Shipping Height
4 cm
Shipping Weight
247 g
P/N: MXT101MM
7RXX StarTech.com USB to VGA Multi Monitor External Video Adapter In Stock £15.41
7RXX StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200 In Stock £14.94
7RXX StarTech.com Slim USB 3.0 to VGA External Video Card Multi Monitor Adapter – 1920x1200 / 1080p In Stock £19.04
7RXX StarTech.com USB 3.0 VGA Video Adapter In Stock £17.63
