StarTech.com USB to Stereo Audio Adapter Converter
Quicklinx: 4YLKWS00 Mfr#: ICUSBAUDIO
Interface: USB 2.0
Sound Output Mode: Stereo
£14.06 ex VAT
£16.87 inc VAT
Turn a USB port into a Stereo Sound Card.
This USB to Stereo Audio Adapter Converter lets you add headsets and microphones to your computer without the need to unplug other devices!
Compliant with USB 2.0 and USB audio device specification 1.0, this USB to audio adapter couldn't be any simpler to install. Compatible with Windows 98SE and up, as well as Mac OS 9.x and later, the USB Audio Adapter integrates into any computer environment, providing superb sound quality and convenience that can't be matched.
  • Versatile compatibility
    Designed to bridge the gap between your computer and audio devices, this USB to Stereo Audio Adapter Converter offers seamless connectivity with both Mac and PC systems. Whether you're enhancing a workstation or setting up a home entertainment system, this adapter ensures your audio needs are met with high-quality stereo output.
  • Easy audio connection
    Featuring two mini-phone stereo 3.5 mm connectors, one for a microphone and another for audio line-out, this adapter simplifies the process of connecting headphones, speakers, or microphones. It's an ideal solution for replacing a damaged sound card or audio port without any software or driver installation required.
  • Compact and portable design
    The external form factor of the USB External Sound Card is not only sleek but also highly portable. Its compact size allows for easy transportation, making it perfect for mobile setups, travel, or optimizing desk space.
StarTech.com USB to Stereo Audio Adapter Converter - USB stereo Adapter - USB External sound Card - Laptop sound Card (ICUSBAUDIO) - sound card
Sound card
Enclosure Type
External
Interface Type
USB 2.0
4 cm x 8 cm x 1.5 cm
54 g
White
Sound Output Mode
Stereo
Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Linux 3.5 or later, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
P/N: MU15MMS, MU6MMS
Sound card
External
Interface Type
USB 2.0
4 cm
8 cm
1.5 cm
54 g
Enclosure Colour
White
Audio Output
Sound Output Mode
Stereo
1 x microphone - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
FCC, RoHS
Software
Drivers & Utilities
Limited warranty - 2 years , Technical support - lifetime
4YLK StarTech.com USB to Stereo Audio Adapter Converter In Stock £14.06
4YLK StarTech.com USB Stereo Audio Adapter External Sound Card In Stock £14.49
4YLK StarTech.com 4 Port Black USB 2.0 Hub In Stock £20.37
4YLK StarTech.com USB Stereo Audio Adapter External Sound Card with SPDIF Digital Audio In Stock £24.36
Resources
The following resources are available for the StarTech.com USB to Stereo Audio Adapter Converter
Interface: USB 2.0
