Turn a USB port into a Stereo Sound Card.
This USB to Stereo Audio Adapter Converter lets you add headsets and microphones to your computer without the need to unplug other devices!
Compliant with USB 2.0 and USB audio device specification 1.0, this USB to audio adapter couldn't be any simpler to install. Compatible with Windows 98SE and up, as well as Mac OS 9.x and later, the USB Audio Adapter integrates into any computer environment, providing superb sound quality and convenience that can't be matched.
- StarTech.com USB to Stereo Audio Adapter Converter - USB stereo Adapter - USB External sound Card - Laptop sound Card (ICUSBAUDIO) - sound card
- Sound card
- Enclosure Type
- External
- Interface Type
- USB 2.0
- 4 cm x 8 cm x 1.5 cm
- 54 g
- White
- Sound Output Mode
- Stereo
- System Requirements
- Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Linux 3.5 or later, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
- 2-year warranty
- Designed For
- P/N: MU15MMS, MU6MMS
- Sound card
- Form Factor
- External
- Interface Type
- USB 2.0
- 4 cm
- 8 cm
- 1.5 cm
- 54 g
- Enclosure Colour
- White
Audio Output
- Sound Output Mode
- Stereo
- 1 x microphone - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
- FCC, RoHS
- Software
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years , Technical support - lifetime
- Designed For
StarTech.com USB to Stereo Audio Adapter Converter | In Stock | £14.05 |
StarTech.com USB Stereo Audio Adapter External Sound Card | In Stock | £14.50 |
StarTech.com 4 Port Black USB 2.0 Hub | In Stock | £20.37 |
StarTech.com USB Stereo Audio Adapter External Sound Card with SPDIF Digital Audio | In Stock | £24.09 |
