StarTech.com USB to Serial Cable - Win/Mac
Quicklinx: GTBFWS00 Mfr#: 1P3FP-USB-SERIAL
Length: 1m
43 In Stock
£16.11 ex VAT
£19.33 inc VAT
3ft (1m) USB to Serial Cable, DB9 Male RS232 to USB Converter, USB to Serial Adapter for PLC/Printer/Scanner/Network Switches, USB to COM Port Adapter - Prolific IC, Automatic Handshake, Windows/macOS (1P3FP-USB-SERIAL).
  • Effortless connectivity
    This USB to Serial Cable offers a seamless connection between your PC and legacy serial devices. With its screwable 9-pin D-Sub (DB-9) connector and a 4-pin USB Type-A, it ensures a secure and stable connection for reliable data transfer.
  • Broad compatibility
    Designed to support a wide range of operating systems, this adapter is compatible with both Windows and macOS. Its versatility makes it an ideal solution for connecting PLCs, printers, scanners, and network switches to your computer.
  • High standards compliance
    Adhering to USB and USB 2.0 compliant standards, along with IC and RoHS certifications, this cable ensures high-quality performance and reliability. Its construction meets rigorous standards to ensure optimal data transmission.
StarTech.com 3ft (1m) USB to Serial Cable, DB9 Male RS232 to USB Converter, USB to Serial Adapter for PLC/Printer/Scanner/Network Switches, USB to COM Port Adapter - Prolific IC, Automatic Handshake, Windows/macOS (1P3FP-USB-SERIAL) - serial cable - DB-9 to USB - 1 m
Serial cable
Length
1 m
Connector
9 pin D-Sub (DB-9) - male - screwable
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
3-year warranty
Serial cable
Length
1 m
Connector
USB / USB 2.0, IC, RoHS
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Weight
91 g
3-year warranty
GTBF StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.50
GTBF StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.81
GTBF StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.38
GTBF StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.49
GTBF StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.00
GTBF StarTech.com 3ft/1m USB to Serial Cable In Stock £32.54
GTBF StarTech.com 10ft/3m USB to RS232 Serial Adapter In Stock £39.64
GTBF StarTech.com 10ft/3m USB to Null Modem Serial Cable In Stock £39.64
GTBF StarTech.com 3ft (1m) USB to Null Modem Serial Cable In Stock £29.07
GTBF StarTech.com 2ft 2-Port USB to RS232 Serial Adapter In Stock £49.17
GTBF StarTech.com 13ft 2-Port USB to RS232 Serial Adapter In Stock £57.30
GTBF StarTech.com 6.6ft/2m USB to Serial Adapter In Stock £28.75
GTBF StarTech.com USB Serial DCE Adapter Cable 2m In Stock £26.75
Length: 1m
