3ft (1m) USB to Serial Cable, DB9 Male RS232 to USB Converter, USB to Serial Adapter for PLC/Printer/Scanner/Network Switches, USB to COM Port Adapter - Prolific IC, Automatic Handshake, Windows/macOS (1P3FP-USB-SERIAL).
Effortless connectivity
This USB to Serial Cable offers a seamless connection between your PC and legacy serial devices. With its screwable 9-pin D-Sub (DB-9) connector and a 4-pin USB Type-A, it ensures a secure and stable connection for reliable data transfer. -
Broad compatibility
Designed to support a wide range of operating systems, this adapter is compatible with both Windows and macOS. Its versatility makes it an ideal solution for connecting PLCs, printers, scanners, and network switches to your computer. -
High standards compliance
Adhering to USB and USB 2.0 compliant standards, along with IC and RoHS certifications, this cable ensures high-quality performance and reliability. Its construction meets rigorous standards to ensure optimal data transmission.
- StarTech.com 3ft (1m) USB to Serial Cable, DB9 Male RS232 to USB Converter, USB to Serial Adapter for PLC/Printer/Scanner/Network Switches, USB to COM Port Adapter - Prolific IC, Automatic Handshake, Windows/macOS (1P3FP-USB-SERIAL) - serial cable - DB-9 to USB - 1 m
- Serial cable
- Length
- 1 m
- Connector
- 9 pin D-Sub (DB-9) - male - screwable
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- 3-year warranty
- Serial cable
- Length
- 1 m
- Connector
- USB / USB 2.0, IC, RoHS
- Shipping Width
- 22 cm
- Shipping Depth
- 20 cm
- Shipping Weight
- 91 g
- 3-year warranty
StarTech.com 1m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.42 |
StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £5.02 |
StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F | In Stock | £4.35 |
StarTech.com 1m Black DB9 RS232 Serial Null Modem Cable F/M | In Stock | £5.01 |
StarTech.com 3ft/1m USB to Serial Cable | In Stock | £32.13 |
StarTech.com 10ft/3m USB to RS232 Serial Adapter | In Stock | £38.56 |
StarTech.com 10ft/3m USB to Null Modem Serial Cable | In Stock | £38.56 |
StarTech.com 3ft (1m) USB to Null Modem Serial Cable | In Stock | £28.71 |
StarTech.com 2ft 2-Port USB to RS232 Serial Adapter | In Stock | £47.73 |
StarTech.com 13ft 2-Port USB to RS232 Serial Adapter | In Stock | £47.40 |
StarTech.com 6.6ft/2m USB to Serial Adapter | In Stock | £27.95 |
StarTech.com USB Serial DCE Adapter Cable 2m | In Stock | £27.21 |
StarTech.com USB Serial DCE Adapter Cable | In Stock | £20.84 |
