StarTech.com USB to RS232 Serial Adapter
Quicklinx: 95Q0WS00 Mfr#: ICUSB232V2
38 In Stock
£16.28 ex VAT
£19.53 inc VAT
Add an RS232 serial port to your laptop or desktop computer through USB. The ICUSB232V2 1 Port USB to Serial Adapter converts a USB port into an RS232 DB9 serial port to connect to, monitor, and control a serial device.
Supporting data transfer rates up to 921.6 Kbps, the USB to serial cable is a convenient and cost-saving solution for providing serial connectivity to devices such as point-of-sale terminals, serial modems, industrial equipment, and a wide variety of other RS232 peripherals.
The USB to RS232 converter is easy to install and offers broad operating system compatibility, including Windows 8, Linux and Mac OS, for easy integration into mixed environments.
  • Durable construction
    The integrated design of this USB to Serial RS232 Adapter ensures long-lasting performance, making it a reliable choice for connecting various serial devices.
  • Compact length
    At 43 cm, this adapter is compact enough for easy storage and portability without sacrificing functionality.
  • Fast data transmission
    With a data transfer rate of up to 921.6 Kbps, this adapter facilitates efficient data communication between devices.
  • Environmentally compliant
    The adapter meets FCC and RoHS standards, ensuring it is safe for use and minimizes environmental impact.
StarTech.com 1 Port USB to Serial RS232 Adapter - Prolific PL-2303 - USB to DB9 Serial Adapter Cable - RS232 Serial Converter (ICUSB232V2) - serial adapter - USB 2.0 - RS-232
Serial adapter
External
Interface (Bus) Type
USB 2.0
Ports
RS-232
52.5 g
RS-232
Data Transfer Rate
921.6 Kbps
Apple MacOS 9.x, Apple MacOS 8.x, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Linux Kernel 2.4.31 or later, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
3-year warranty
Serial adapter
External
USB 2.0
Ports
RS-232
Wired
RS-232
Data Transfer Rate
921.6 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB cable (integrated) - 43 cm
FCC, RoHS
52.5 g
Limited warranty - 3 years
60 °C
