StarTech.com USB to Lightning Cable Coiled
Quicklinx: GPJRWS00 Mfr#: RUSB2ALT50CMBC
Length: 50cm
£10.87 ex VAT
£13.04 inc VAT
This coiled Lightning to USB A cable can withstand the daily demands of charging and syncing your mobile devices. It contracts to 1ft (30cm) making it compact and convenient to store.
  • Built for Daily Use
    The durable Lightning charging cable has aramid fiber reinforcement that shelters it from the stress of frequent bends. This also lets the cable flex without over-stretching or damaging the core of the cable.
  • Flexible Strain Relief
    The Lightning to USB A cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 5,000+ bend cycles at a 180° angle.
  • Superior Connection
    The durable cable supports all USB 2.0 specifications providing a dependable connection for all your Lightning devices. It is also Apple MFi certified which is guaranteed for fast and reliable charge and sync from USB-A charging ports. RUSB2ALT50CMBC is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 50cm (20in) USB to Lightning Cable, MFi Certified, Coiled iPhone Charger Cable, Black, Durable and Flexible TPE Jacket Aramid Fiber, Heavy Duty Coil Charging Cable - Rugged USB Lightning Cable - Lightning cable - Lightning / USB - 50 cm
Cable
American Wire Gauge (AWG)
22/32
Length
50 cm
Connector
USB - male
Connector (Second End)
Lightning - male
Coiled
Cable Type
Lightning cable coiled
Interface Supported
Lightning / USB
22/32
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
50 cm
Plated Connector
Nickel
Sync and charge, strain relief, aramid reinforced core
Connector
4 pin USB Type A - male
Apple Lightning - male
MFI, RoHS, WEEE
Shipping Width
14.5 cm
Shipping Depth
7.5 cm
Shipping Height
1.7 cm
Shipping Weight
30 g
Length: 50cm
