Add Gigabit Ethernet connectivity and two USB 3.0 ports to your laptop or tablet through a single USB port. Add powerful network access to your tablet, Ultrabook or laptop, even if it doesn't have a built-in RJ45 port. This USB 3.0 to Gigabit network adapter gives you wired network access - and provides two USB 3.0 pass-through ports allowing you to connect additional USB devices.
Ideal for office or home use, the USB 3.0 network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.0 (5 Gbps). You can quickly access very large files over a Gigabit network, saving valuable time every day.
Get up and running quickly. Simply plug this Ethernet cable adapter into the USB port on your laptop and connect to your network. The network adapter chipset provides native driver support, so you don't have to worry about installing additional software.
Enhance the capabilities of your laptop or tablet by connecting USB devices like printers or external solid-state drive or hard drive enclosures using the two USB 3.0 ports. You can also connect your mouse, keyboard, flash drive or other low-power USB devices, with no extra power required.
Compact and portable, this USB Gigabit network adapter is the ideal desktop network adapter or laptop accessory. You don't have to carry a power adapter with you to use it, because it's powered directly from the host USB port.
Powerful Gigabit network connections
Ideal for office or home use, the USB 3.0 network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.0 (5 Gbps). You can quickly access very large files over a Gigabit network, saving valuable time every day. -
Native driver support makes installation easy
Get up and running quickly. Simply plug this Ethernet cable adapter into the USB port on your laptop and connect to your network. The network adapter chipset provides native driver support, so you don't have to worry about installing additional software. -
Connect your USB devices to the additional ports
Enhance the capabilities of your laptop or tablet by connecting USB devices like printers or external solid-state drive or hard drive enclosures using the two USB 3.0 ports. You can also connect your mouse, keyboard, flash drive or other low-power USB devices, with no extra power required. -
Compact and lightweight for perfect portability
Compact and portable, this USB Gigabit network adapter is the ideal desktop network adapter or laptop accessory. You don't have to carry a power adapter with you to use it, because it's powered directly from the host USB port. The USB31000S2H is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com 2 Port USB 3.0 Hub with Ethernet - USB 3.0 x 2 - Gigabit Ethernet Network Adapter for Windows / Mac / Chrome (USB31000S2H) - network adapter - USB 3.0 - Gigabit Ethernet x 1
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- 6 cm 2 cm
- Length
- 25 cm
- 60 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Capacity
- Jumbo frame size: 9000
- Processor
- Realtek Semiconductor RTL8153
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
- Black
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.7 - 10.15, Apple macOS 11.0, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- 2-year warranty
- Network adapter
- Form Factor
- External
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- Capacity
- Full duplex capability, WOL, auto-uplink (auto MDI/MDI-X), USB powered, surge protection, built-in 2-port USB 2.0 hub, Jumbo Frames support, Energy Efficient Ethernet, VLAN Tagging (not supported in MacOS)
Processor / Memory
- Processor
- 1 x 1000Base-T - RJ-45 - female , 2 x USB 3.0 - 9 pin USB Type A - female
- UL, FCC, RoHS
- Black
- 1092 mAh
- OS Required
- 6 cm
- 2 cm
- Length
- 25 cm
- 60 g
- Limited warranty - 2 years
- 0 °C
- 70 °C
StarTech.com 2 Port ExpressCard SuperSpeed USB 3.0 Card Adapter with UASP Support | In Stock | £21.26 |
StarTech.com USB 3.0 Network Adapter-Silver | In Stock | £23.74 |
StarTech.com 3Pt Portable USB 3.0 Hub + GbE | In Stock | £34.00 |
StarTech.com USB to Ethernet Adapter - 1Gb
