StarTech.com USB to Ethernet Adapter - 1Gb
Quicklinx: GMBQWS00 Mfr#: USB31000S2
Wired / Wireless: Wired
Protocol: Gigabit Ethernet, Ethernet, Fast Ethernet
Form Factor: External
Compatibility: Unix, Mac, PC
Type: Network adapter
39 In Stock
£19.78 ex VAT
£23.73 inc VAT
Add Gigabit Ethernet connectivity and two USB 3.0 ports to your laptop or tablet through a single USB port. Add powerful network access to your tablet, Ultrabook or laptop, even if it doesn't have a built-in RJ45 port. This USB 3.0 to Gigabit network adapter gives you wired network access - and provides two USB 3.0 pass-through ports allowing you to connect additional USB devices.
Ideal for office or home use, the USB 3.0 network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.0 (5 Gbps). You can quickly access very large files over a Gigabit network, saving valuable time every day.
Get up and running quickly. Simply plug this Ethernet cable adapter into the USB port on your laptop and connect to your network. The network adapter chipset provides native driver support, so you don't have to worry about installing additional software.
Enhance the capabilities of your laptop or tablet by connecting USB devices like printers or external solid-state drive or hard drive enclosures using the two USB 3.0 ports. You can also connect your mouse, keyboard, flash drive or other low-power USB devices, with no extra power required.
Compact and portable, this USB Gigabit network adapter is the ideal desktop network adapter or laptop accessory. You don't have to carry a power adapter with you to use it, because it's powered directly from the host USB port.
  • Powerful Gigabit network connections
  • Native driver support makes installation easy
  • Connect your USB devices to the additional ports
  • Compact and lightweight for perfect portability
    Compact and portable, this USB Gigabit network adapter is the ideal desktop network adapter or laptop accessory. You don't have to carry a power adapter with you to use it, because it's powered directly from the host USB port. The USB31000S2H is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 2 Port USB 3.0 Hub with Ethernet - USB 3.0 x 2 - Gigabit Ethernet Network Adapter for Windows / Mac / Chrome (USB31000S2H) - network adapter - USB 3.0 - Gigabit Ethernet x 1
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
6 cm 2 cm
Length
25 cm
60 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Jumbo frame size: 9000
Realtek Semiconductor RTL8153
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.7 - 10.15, Apple macOS 11.0, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Network adapter
External
SuperSpeed USB 3.0
Ports
Wired
Cabling Type
Full duplex capability, WOL, auto-uplink (auto MDI/MDI-X), USB powered, surge protection, built-in 2-port USB 2.0 hub, Jumbo Frames support, Energy Efficient Ethernet, VLAN Tagging (not supported in MacOS)
Processor / Memory
1 x 1000Base-T - RJ-45 - female , 2 x USB 3.0 - 9 pin USB Type A - female
UL, FCC, RoHS
1092 mAh
6 cm
2 cm
Length
25 cm
60 g
70 °C
GMBQ StarTech.com USB 3.0 Network Adapter-Silver In Stock £23.53
GMBQ StarTech.com 3Pt Portable USB 3.0 Hub + GbE In Stock £33.70
Protocol: Ethernet
Protocol: Fast Ethernet
Compatibility: Unix
Compatibility: Mac
Compatibility: PC
